It discusses the choice of the packaging system. We plan to use native packaging systems (i.e. deb and rpm formats).
Let us know if you have any thoughts on that!
I think package repository it will be rigth way (for .deb .rpm) Autoupdater can be just simple command in cron like āyum update storagenodeā or apt āupdate storagenodeā that run every 6 hour ± randomization.
Also nice to have āhow to build it from sourceā small documentation for other distros.
How will this offer a better experience than using docker? It needs to be at least as simple to setup as using docker. Hopefully a simple one line command to install and a text config file to update.
