Hello,
I just registered that my Ubuntu-System-Time is exactly 1 hour ahead of the Node-System-Time.
The Ubuntu-System-Time is the correct one.
Ubuntu:
Node:
Is that a problem, and if so, how to change it?
Hello,
Ubuntu:
Node:
Mine looks a bit different:
What can I do?
On your screen with time sync. looks like everything is OK, on ubuntu, it is systemd-timesyncd service that responsible for NTP synchronization and it working fine on your side. On your screenshot in the first post, I see that your tray clock is showing local time (CET timezone), but storage node show time on UTC timezone it’s normal and you no need to worry.
Ok, thank you.
Good to not get DQ because of that.
