Directory listing using Filezilla stopped working
Am getting the following error:
Error: Failed to retrieve directory listing
Status: Disconnected from server
Status: Connecting to eu1.storj.io…
Status: Retrieving directory listing of /admin…
Command: list /admin
Error: Connection timed out after 20 seconds of inactivity
Am failing to debug this. Can you assist?
Hello @Barukimang ,
Could you please temporary connect via mobile network?
I suspect either your firewall or your ISP are blocking the outgoing traffic.
Hi @Barukimang
I think you may be using the incorrect connection details…
It will work with eu1.storj.io as well if you would use an Access grant instead of API Key + Password
It was working before, but then it stopped working. The settings have not been changed:
Because it looks to me as an ISP issue. Is it XFinity?
Issue solved!
Had the same issue using mobile network:
ISP has bandwidth of 130mb/ps so that is good.
Noticed that /admin file listing through the Storj dashboard also took more than 20 seconds, so adjusted timeout to ‘0’ infinity. That solved the issue.
thanks for giving a right solution… I was also searching for the same solution to my problem. It solved my problem. Thank you
