since 0.29.3 I cant to resize (increase) node allocated size. it just ignore new size and always shows old value in console dashboard.
I do this more than once for different nodes and everything worked before.
what is happening?
We have crystal ball synchronized both, cheers.
But this does not work
I would say rename your old config.yaml.bak making sure its not over writing your settings.
looks like minimum size of expansion is about 100gb
