Disk usage discrepancy?
If you did all optimizations for the filesystem mentioned before, and you still have failed the lazy filewalker, then the only thing is to disable a lazy mode
Save the config and restart the node. After that the progress you can track only by using a debug port
or this trick:
So I turned off lazy firewalker. I was looking at moving my db’s to a ssd but the instructions I found online are not working or I am missing something. To move the databases I stopped the windows storjnode service. Copied all the .db files from the current location to the new (ssd) deleted the original and uncommented the path in the config file and saved it but when I go to start the service it fails. The only way to get it to start again is to move the .db files back to the original location. What am I missing?
I figured it out the “” had to be removed from the path
@Alexey I more and more think this is a bug.
no error about filewalker in last 10 days found. I have WARN log level
I have 5tb hdd and 854 GB of free space.
How we can investigate it?
I have a feeling this may be related to how the trash-cleanup-filewalker only updates the used trash only after successful completion. So if your node restarts from update or host reboot while it is emptying the trash, the node would have lost track of the data it has actually deleted.
The fix would be to run the used-space filewalker.
tried, restarts with active used space, not helping.
Also if it would 1 node, but there is lot of nodes like this.
it is also impact productivity, because nodes cant get data. I have 50 TB of trash like this.
I understand that it is not all of this trash like this, but looks like it is the most.
During the update, the node was restarted and the total capacity decreased significantly. Last time, I loaded the capacity all at once, but this time, I’m worried because it seems like the smaller node will remain the same…
Other nodes that had the same problem of reduced capacity when turning the node off and on have not returned to their original state, which is frustrating, but the same problem is happening to this node as well… :smiling_face_with_tear:
If you mean the piechart, then this is mean that the databases are not updated.
You need to search for errors related to a databases/filewalkers in your logs. If you didn’t disable the scan on startup, then the used-space-filewalker should fill databases on the successful finish for each trusted satellite.
If you mean the Average Disk Space Used This Month, then it’s again missing reports from US1 and SLC, I hope these satellites would finish the report and send it later.
If the node on 1.104.x, then there is a bug with not updating databases by a trash filewalker. It has been fixed only in 1.105.x as far as I know.
However, to update it, the one scan is required after the upgrade.
I am on 1.105.x from day one, that it was out. so it is enough time that scan happened. I Activated it also on start. Yesterday I made also log level info on one of the node to see that it end, to check the results.
2024-07-01T01:40:03Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-07-01T01:40:03Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
2024-07-01T01:40:03Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-07-01T01:40:30Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-07-01T01:40:30Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-07-01T01:40:30Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-07-01T01:40:30Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-07-01T01:40:30Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-07-01T01:40:30Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
2024-07-01T01:40:30Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-07-01T03:26:44Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-07-01T03:26:44Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-07-01T03:26:44Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-07-01T03:26:44Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-07-01T03:26:44Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-07-01T03:26:44Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
2024-07-01T03:26:44Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-07-01T03:31:33Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-07-01T03:31:33Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-07-01T03:31:33Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-07-01T03:31:33Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-07-01T03:31:33Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-07-01T03:31:33Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
2024-07-01T03:31:33Z    ERROR   pieces  failed to lazywalk space used by satellite      {"Process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
No matter how much I search for information about File Walker, it’s beyond my capabilities. I can’t think of a single solution. It’s the same as last time
I feel lost. :frowning:
root@STORJ_NO1:~# docker exec -it storagenode /app/storagenode info
2024-07-01T04:50:50Z    INFO    Anonymized tracing enabled      {"Process": "storagenode"}
2024-07-01T04:50:50Z    FATAL   Failed to load identity.        {"Process": "storagenode", "error": "file or directory not found: open /root/.local/share/storj/identity/storagenode/identity.cert: no such file or directory", "errorVerbose": "file or directory not found: open /root/.local/share/storj/identity/storagenode/identity.cert: no such file or directory\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdInfo:67\n\tmain.newNodeInfoCmd.func1:42\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:267"}
When I searched info, FATAL came up. Is this why?
I don’t have to fill in each trusted satellite myself, right? It will be automatically filled over time, right?
sudo docker run -d --restart unless-stopped --stop-timeout 300 \
    -p 28967:28967/tcp \
    -p 28967:28967/udp \
    -p 14002:14002 \
    -p 5999:5999 \
    -e WALLET="0xCbc" \
    -e EMAIL="***@gmail.com" \
    -e ADDRESS="***:28967" \
    -e STORAGE="14.3TB" \
    --log-driver json-file \
    --log-opt max-size=10m \
    --log-opt max-file=5 \
    --user $(id -u):$(id -g) \
    --mount type=bind,source="/volume2/storj/identity",destination=/app/identity \
    --mount type=bind,source="/volume2/storj/data",destination=/app/config \
    --mount type=bind,source="/volume2/storj/data/node.log",destination=/app/logs/node.log \
    --name storagenode storjlabs/storagenode:latest \
    --log.output=/app/logs/node.log \
    --server.address=":28967" \
    --console.address=":14002" \
    --debug.addr=":5999" \
    --log.level=error \
    --filestore.write-buffer-size 4MiB \
    --pieces.write-prealloc-size 4MiB \
    --operator.wallet-features=zksync
This is the default setting.
yes. It cannot find the identity files.
Could you please copy the result of the command:
sudo ls -l /volume2/storj/identity
yes, if the filewalkers will finish scan successfully and updates the database.
root@STORJ_NO1:~# sudo ls -l /volume2/storj/identity
total 24
-rwxrwxrwx+ 1 root root  558 Apr  8 18:19 ca.1712567987.cert
-rwxrwxrwx+ 1 root root 1088 Apr  8 18:19 ca.cert
-rwxrwxrwx+ 1 root root  241 Apr  8 18:13 ca.key
-rwxrwxrwx+ 1 root root 1096 Apr  8 18:19 identity.1712567987.cert
-rwxrwxrwx+ 1 root root 1626 Apr  8 18:19 identity.cert
-rwxrwxrwx+ 1 root root  241 Apr  8 18:13 identity.key
So, why it cannot see it?
Does your hard drive turn off from time to time?
Except for today’s update, it hasn’t been turned off recently…
I mean not the node itself, but the HDD. If it would disappear, then for the node it would be not accessible. Otherwise I do not know, how the node could not see an identity.
I could guess, but maybe it was a temporary issue, but from your logs it looks like the node is restarted for some unknown reason and cannot find an identity on restart.
Does it work now?
Regarding issues with a used-space-filewalker. Since it cannot finish the scan, your databases will remain not updated. So, you likely need either improve the speed of the disk subsystem (by adding more RAM or configure SSD to be a cache layer), or disable the lazy mode and allow the filewalker to update databases, then enable the lazy mode back.
These days, ingress fills up quickly, so what happens if the original capacity is exceeded after the scan is completed? The original empty space is about 2 tera, but at today’s speed, it will be filled in about 4 to 5 days. If the scan is completed and returns to normal after that, the storage space will likely be overloaded.
I’m using Synology, but I don’t know how to check for symptoms of HDD stopping!
