There is an emergency check - if the free space in the allocation or on the disk is lower than 5GB, the node will immediately report to the satellites, that’s full.
Can you please send me a link to do this? I looked at many forums but there were so many that it was difficult to determine which one corresponded to my symptoms.
You should have some logs entries on the Synology, if the disk is disappearing. Is it an external HDD? If so, it need to have an additional power supply.
It is not an external hard drive. ![]()
it’s also possible to specify it as a command line argument in your docker run command after the image name as --pieces.enable-lazy-filewalker=false
However, after that you would not see filewalker in your logs, you need to track it differently
See here:
https://forum.storj.io/t/my-docker-run-commands-for-multinodes-on-synology-nas/22034?u=snorkel
I don’t use that line about user and group. Try to remove it, because you run it like root; you start it with sudo.
sudo docker run -d --restart unless-stopped --stop-timeout 300 \
-p 28967:28967/tcp \
-p 28967:28967/udp \
-p 14002:14002 \
-p 5999:5999 \
-e WALLET="0xCb97E443b7458eE" \
-e EMAIL="***@gmail.com" \
-e ADDRESS="***:28967" \
-e STORAGE="14.3TB" \
--log-driver json-file \
--log-opt max-size=10m \
--log-opt max-file=5 \
--mount type=bind,source="/volume2/storj/identity",destination=/app/identity \
--mount type=bind,source="/volume2/storj/data",destination=/app/config \
--mount type=bind,source="/volume2/storj/data/node.log",destination=/app/logs/node.log \
--name storagenode storjlabs/storagenode:latest \
--log.output=/app/logs/node.log \
--storage2.piece-scan-on-startup=true \
--server.address=":28967" \
--console.address=":14002" \
--debug.addr=":5999" \
--log.level=error \
--filestore.write-buffer-size 4MiB \
--pieces.write-prealloc-size 4MiB \
--operator.wallet-features=zksync \
--pieces.enable-lazy-filewalker=false \
I configured lazy-filewalkers and restarted. Can I just leave it like this?
There doesn’t seem to be any change in my eyes right away, so it seems like it’s going to take some time, right?
I’m sorry to bother you.
As you suggested in the link, I removed --user $(id -u):$(id -g)! ![]()
F:\storagenode.log:90113951:2024-06-29T17:31:02+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
F:\storagenode.log:90113954:2024-06-29T17:31:02+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
F:\storagenode.log:90113957:2024-06-29T17:31:02+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
F:\storagenode.log:90114044:2024-06-29T17:31:02+01:00 ERROR filewalker failed to get progress from database {"error":
"gc_filewalker_progress_db: context canceled", "errorVerbose": "gc_filewalker_progress_db: context canceled\n\tstorj.io
/storj/storagenode/storagenodedb.(*gcFilewalkerProgressDB).Get:47\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).Wa
lkSatellitePiecesToTrash:154\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:565\n\tstorj.io/s
torj/storagenode/retain.(*Service).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgo
lang.org/x/sync/errgroup.(*Group).Go.func1:78"}
F:\storagenode.log:90114045:2024-06-29T17:31:02+01:00 ERROR filewalker failed to reset progress in database {"error":
/storj/storagenode/storagenodedb.(*gcFilewalkerProgressDB).Reset:58\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).
WalkSatellitePiecesToTrash.func1:171\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePiecesToTrash:244\
n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:565\n\tstorj.io/storj/storagenode/retain.(*Ser
vice).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgolang.org/x/sync/errgroup.(*Gr
oup).Go.func1:78"}
F:\storagenode.log:90114055:2024-06-29T17:32:31+01:00 ERROR failure during run {"error": "Error migrating tables for
database on storagenode: migrate: database: info opening file \"F:\\\\info.db\" failed: context canceled\n\tstorj.io/st
orj/storagenode/storagenodedb.(*DB).openDatabase:364\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).Migration.func1:
684\n\tstorj.io/storj/private/migrate.(*Migration).Run:167\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToL
atest:387\n\tmain.cmdRun:98\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/commo
n/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).Execu
teC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstor
j.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/com
mon/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78",
"errorVerbose": "Error migrating tables for database on storagenode: migrate: database: info opening file
\"F:\\\\info.db\" failed: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:364\n\tstorj.
io/storj/storagenode/storagenodedb.(*DB).Migration.func1:684\n\tstorj.io/storj/private/migrate.(*Migration).Run:167\n\t
storj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:387\n\tmain.cmdRun:98\n\tmain.newRunCmd.func1:33\n\tstor
j.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Comman
d).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\t
storj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.
io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgo
lang.org/x/sync/errgroup.(*Group).Go.func1:78\n\tmain.cmdRun:100\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.
cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgi
thub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/proc
ess.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.Ex
ecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errg
F:\storagenode.log:90114056:2024-06-29T17:32:31+01:00 FATAL Unrecoverable error {"error": "Error migrating tables for
F:\storagenode.log:90114373:2024-06-29T17:37:00+01:00 ERROR failure during run {"error": "Invalid configuration:
invalid contact.external-address: lookup \"mystorjtoshiba.ddns.net\" failed: lookup mystorjtoshiba.ddns.net:
getaddrinfow: A non-recoverable error occurred during a database lookup.\n\tstorj.io/storj/storagenode.(*Config).Verify
:171\n\tmain.cmdRun:61\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/pro
cess.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1
115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/
common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/p
"errorVerbose": "Invalid configuration: invalid contact.external-address: lookup \"mystorjtoshiba.ddns.net\" failed:
lookup mystorjtoshiba.ddns.net: getaddrinfow: A non-recoverable error occurred during a database lookup.\n\tstorj.io/st
orj/storagenode.(*Config).Verify:171\n\tmain.cmdRun:61\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.fu
nc1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/s
pf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWi
thCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCust
omConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Gro
up).Go.func1:78\n\tmain.cmdRun:62\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io
/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command)
.ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n
\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.
io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
F:\storagenode.log:90114374:2024-06-29T17:37:00+01:00 FATAL Unrecoverable error {"error": "Invalid configuration:
F:\storagenode.log:90115620:2024-06-29T17:47:17+01:00 INFO lazyfilewalker.used-space-filewalker subprocess exited with
status {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": 1, "error": "exit status 1"}
I have done defrag the disk using Iobit Smart defrag
Doing the system repaire now
didnt understand what i need to do for point 2,3 5
Hello,
as you can see on screens below, I have a problem with disk space and what node sees on disk. The difference is huge.
I looked the logs, there is some error with the lazyfilewalker, but dont know what I can do.
I am running a CHKDSK. Not even sure what parameters should I use : x/ c/ r/ ?
Ligne 16: 2024-06-16T21:57:03+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 19: 2024-06-16T21:57:03+02:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 23: 2024-06-16T21:57:03+02:00 INFO lazyfilewalker.gc-filewalker starting subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 25: 2024-06-16T21:57:03+02:00 INFO lazyfilewalker.gc-filewalker starting subprocess {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 26: 2024-06-16T21:57:03+02:00 INFO lazyfilewalker.used-space-filewalker subprocess started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 27: 2024-06-16T21:57:03+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 30: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 32: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.gc-filewalker subprocess started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 33: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "dateBefore": "2024-06-09T21:57:03+02:00", "Process": "storagenode"}
Ligne 36: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
Ligne 37: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
Ligne 38: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 41: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 43: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 44: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
Ligne 45: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
Ligne 46: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
Ligne 47: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "bloomFilterSize": 10215237, "Process": "storagenode", "createdBefore": "2024-05-30T19:59:59+02:00"}
Ligne 48: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.gc-filewalker.subprocess Database started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
Ligne 49: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.gc-filewalker.subprocess gc-filewalker started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "createdBefore": "2024-06-09T19:59:59+02:00", "bloomFilterSize": 11917820}
Ligne 50: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-06-09T21:57:04+02:00"}
Ligne 52: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
Ligne 53: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
Ligne 54: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 57: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 58: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 61: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "dateBefore": "2024-06-09T21:57:04+02:00"}
Ligne 62: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode"}
Ligne 63: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
Ligne 64: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 67: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 68: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 70: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker started {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "dateBefore": "2024-06-09T21:57:04+02:00", "Process": "storagenode"}
Ligne 71: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess Database started {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
Ligne 72: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker.subprocess trash-filewalker completed {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "numKeysDeleted": 0, "Process": "storagenode", "bytesDeleted": 0}
Ligne 73: 2024-06-16T21:57:04+02:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 714: 2024-06-16T21:58:59+02:00 INFO lazyfilewalker.gc-filewalker subprocess exited with status {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "status": 1, "error": "exit status 1"}
Ligne 715: 2024-06-16T21:58:59+02:00 ERROR pieces lazyfilewalker failed {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:558\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Ligne 717: 2024-06-16T21:58:59+02:00 INFO lazyfilewalker.used-space-filewalker subprocess exited with status {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": 1, "error": "exit status 1"}
Ligne 718: 2024-06-16T21:58:59+02:00 INFO lazyfilewalker.gc-filewalker subprocess exited with status {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": 1, "error": "exit status 1"}
Ligne 719: 2024-06-16T21:58:59+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 720: 2024-06-16T21:58:59+02:00 ERROR pieces lazyfilewalker failed {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:558\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Ligne 726: 2024-06-16T21:58:59+02:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 727: 2024-06-16T21:58:59+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
Ligne 728: 2024-06-16T21:58:59+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 729: 2024-06-16T21:58:59+02:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 730: 2024-06-16T21:58:59+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
Ligne 731: 2024-06-16T21:58:59+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 732: 2024-06-16T21:58:59+02:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 733: 2024-06-16T21:58:59+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
Ligne 734: 2024-06-16T21:58:59+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 742: 2024-06-16T22:00:18+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 3231: 2024-06-21T03:05:53+02:00 ERROR pieces:trash emptying trash failed {"error": "pieces error: lazyfilewalker: exit status 1", "errorVerbose": "pieces error: lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:187\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:419\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
Ligne 3235: 2024-06-21T03:05:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
Ligne 3236: 2024-06-21T03:05:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 3237: 2024-06-21T03:05:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
Ligne 3238: 2024-06-21T03:05:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 3239: 2024-06-21T03:05:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
Ligne 3240: 2024-06-21T03:05:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 3243: 2024-06-21T03:05:56+02:00 ERROR pieces lazyfilewalker failed {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:558\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Ligne 3247: 2024-06-21T03:05:57+02:00 ERROR pieces lazyfilewalker failed {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:558\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Ligne 9153: 2024-06-29T22:47:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 9154: 2024-06-29T22:47:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
Ligne 9155: 2024-06-29T22:47:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 9156: 2024-06-29T22:47:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
Ligne 9157: 2024-06-29T22:47:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 9158: 2024-06-29T22:47:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
Ligne 9159: 2024-06-29T22:47:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:704\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
Ligne 9161: 2024-06-29T22:47:56+02:00 ERROR pieces lazyfilewalker failed {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:558\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:369\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:258\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Ligne 9941: 2024-07-01T17:59:55+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
Ligne 9942: 2024-07-01T17:59:55+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
Ligne 9943: 2024-07-01T17:59:55+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
Ligne 9944: 2024-07-01T17:59:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
Ligne 9945: 2024-07-01T17:59:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
Ligne 9946: 2024-07-01T17:59:56+02:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
Ligne 9947: 2024-07-01T17:59:56+02:00 ERROR pieces failed to lazywalk space used by satellite {"error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
So if the node can complete it’s filewalkers the disk space should match better. not perfect but better.
I’ve heard the “context canceled” can be cause simply by slow hardware. you’re running windows? What does task manager show as the disk busyness when storj starts up? What about cpu or ram being maxed out? (unlikely)
is the drive a SMR drive? Also unlikely.
Is the drive and file system working okay? Can you manually create a new file on it, etc?
Also you could try editing your config.yaml file, and setting lazy filewalker to false. This will run the “non lazy” file walker right away which might finish better.
status {“satelliteID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “status”: 1, “error”: “exit status 1”}
F:\storagenode.log:95001439:2024-07-01T13:15:02+01:00 INFO lazyfilewalker.used-space-filewalker subprocess exited with
F:\storagenode.log:95001442:2024-07-01T13:15:02+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
subprocess {“satelliteID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “error”: “context canceled”}
F:\storagenode.log:95001445:2024-07-01T13:15:02+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
subprocess {“satelliteID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “error”: “context canceled”}
F:\storagenode.log:95001448:2024-07-01T13:15:02+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
subprocess {“satelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “error”: “context canceled”}
F:\storagenode.log:95011466:2024-07-01T15:34:20+01:00 INFO lazyfilewalker.used-space-filewalker subprocess exited with
F:\storagenode.log:95011469:2024-07-01T15:34:20+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
F:\storagenode.log:95011472:2024-07-01T15:34:20+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
F:\storagenode.log:95011475:2024-07-01T15:34:20+01:00 ERROR lazyfilewalker.used-space-filewalker failed to start
F:\storagenode.log:95034295:2024-07-01T16:04:41+01:00 ERROR orders cleaning DB archive {“error”: “ordersdb: database
is locked”, “errorVerbose”: “ordersdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Clean
Archive:325\n\tstorj.io/storj/storagenode/orders.(*Service).CleanArchive:162\n\tstorj.io/storj/storagenode/orders.(*Ser
vice).Run.func2:146\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolan
g.org/x/sync/errgroup.(*Group).Go.func1:78”}
Thank you for the answer.
It is windows, but the computer doesnt seem slow. Node is the only thing running on it
HDD is CMR. No problem to create a file
I will try disabling lazyfilewalker
yeah system seems fine except for the hard drive being maxed out 100%.
Check the HDD utilization when not running storj at all, make sure something else isn’t using it.
Also maybe reduce your node size to less than the current size, so that it’s not trying to ingress new data (increasing load) while also doing filewalkers.
if you can make it through the filewalkers successfully then you can restore your node size to the normal desired.
is it an USB hard drive or an internal?
You have an extra backslash in the last line in the docker run, it’s placed to allow to add another option after that on the new line. So
should be
otherwise terminal would wait for the input instead of run. Or you would need to hit Enter one more time ![]()
Since now the lazy mode is disabled, the used-space-filewalker will not report to the logs about a progress. So you need to wait until it would finish. You may use these methods to track the progress mentioned above. When it would finish for all satellites and update database, the usage should become close to the actual usage on the disk.
These are old errors from 2024-06-29
The last one is
So, seems also the network is not functioning properly on this setup?
You need to perform the suggested actions in the linked threads, it should optimize the filesystem performance.
The Write cache policy is configured in the Disk Management - Your disk - Properties - Policies.
@Alexey now I have a proof that filewalker not help to resolve virtual trash problem or it Ended only to 1 sattelite?
I found that it started to next sat, so it like week long procest, and if pc restart then start from beggining?
2024-07-02T03:33:03+03:00 INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker completed {“satelliteID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Process”: “storagenode”, “piecesTotal”: 68149138688, “piecesContentSize”: 68006838016}
2024-07-02T03:33:03+03:00 INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {“satelliteID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
in trash there is only 50GB files
You need to have all 4 scans to be completed. I only know that the bug with not updating stats by the trash filewalker is fixed only in 1.105.x, so one scan should be enough to fix usage discrepancies, and the next trash filewalkers should update the stat correctly - it should decrease it. However, I’m not sure how it would be processed, while the used-space-filewalker is still doing the scan and since it’s running too long, it likely would have the usage wrong anyway while the usage always changing.
I understood that now all I had to do was wait. This seems to be the most advanced step that a beginner can do. Thanks to you, I am learning a lot, but it is difficult to take on the challenge without some computer knowledge. I hope the day will come when you can just press Next like in Windows! ![]()
If any new problems arise, I will report them. thank you!
