These are all the useful parameters that one storagenode can use, and the modifications that I use for the second node. Fill free to use them or not, is up to you. I put them here fore easy reference.
These work for Synology NAS and I run them in sudo su mode.
There is also the --user $(id -u):$(id -g) parameter, but I started without it. It seems that dosen’t work on Synology NAS.
OLD CONFIG:
See UPDATED section for the recent version; also read the entire thread to get the picture.
NODE 1, MACHINE 1:
Run only once at install of first node:
echo "net.core.rmem_max=2500000" >> /etc/sysctl.conf
sysctl -w net.core.rmem_max=2500000
docker pull storjlabs/storagenode:latest
docker run --rm -e SETUP="true" \
--mount type=bind,source="/volume1/Storj/Identity/storagenode/",destination=/app/identity \
--mount type=bind,source="/volume1/Storj/",destination=/app/config \
Run at installation or after stoping and removing node, after parameters change:
-p 28967:28967/tcp \
-p 28967:28967/udp \
-p 14002:14002 \
-p 5999:5999 \
-e WALLET="...WALLET..." \
-e EMAIL="...EMAIL..." \
-e ADDRESS="...WAN_IP...:28967" \
-e STORAGE="14TB" \
--log-opt max-size=10m \
--log-opt max-file=5 \
--name storagenode storjlabs/storagenode:latest \
--server.address=":28967" \
--console.address=":14002" \
--debug.addr=":5999" \
--log.level=error \
--filestore.write-buffer-size 4MiB \
--pieces.write-prealloc-size 4MiB \
--storage2.piece-scan-on-startup=true \
--operator.wallet-features=zksync
NODE 2, MACHINE 1:
Run only once at install of seconde node:
--mount type=bind,source="/volume2/Storj2/Identity/storagenode/",destination=/app/identity \
--mount type=bind,source="/volume2/Storj2/",destination=/app/config \
--name storagenode2 storjlabs/storagenode:latest
-p 28968:28968/tcp \
-p 28968:28968/udp \
-p 14003:14003 \
-p 6000:6000 \
-e ADDRESS="...WAP_IP...:28968" \
-e STORAGE="14TB" \
--name storagenode2 storjlabs/storagenode:latest \
--server.address=":28968" \
--console.address=":14003" \
--debug.addr=":6000" \
--log.level=error \
Installing the WATCHTOWER - in this form, it will keep logs small and update all the containers, not only Storj’s:
docker pull storjlabs/watchtower
docker run -d --restart=always --log-opt max-size=10m --log-opt max-file=5 --name watchtower -v /var/run/docker.sock:/var/run/docker.sock storjlabs/watchtower --stop-timeout 300s --notifications-level error
Useful commands:
docker ps -a
docker rm storagenode
docker start storagenode
docker stop -t 300 storagenode2
docker rm storagenode2
docker start storagenode2
docker stop -t 300 watchtower
docker rm watchtower
docker start watchtower
Other useful commands:
#check logs:
docker logs storagenode
docker logs watchtower
#see the last 20 log entries:
docker logs --tail 20 storagenode
#CLI dashboard:
docker exec -it storagenode /app/dashboard.sh
#see all commands:
docker exec -it storagenode /app/storagenode help
#execute commands:
docker exec -it storagenode /app/storagenode <<command>>
UPDATED:
Docker run commands for 2 nodes, 2 drives (Exos), on the same Synology DS220+, DSM 7.x, 18GB RAM, using network host mode, and databases moved to USB flash drive:
Startup scripts in task scheduler (triggered, root, boot-up):
sysctl -w net.core.wmem_max=2500000
sysctl -w net.ipv4.tcp_fastopen=3
If databases are moved to USB:
# This startup script works on Synology (triggered, root, boot-up):
mount -o remount,noatime "/volumeUSB1/usbshare"
Pre-Setup - only one time:
sudo su
echo "net.core.wmem_max=2500000" >> /etc/sysctl.conf
echo "net.ipv4.tcp_fastopen=3" >> /etc/sysctl.conf
Setup - only one time before you start the node, to setup the directories and etc.
sudo su
--mount type=bind,source="/volume1/Storj1/Identity/storagenode/",destination=/app/identity \
--mount type=bind,source="/volume1/Storj1/",destination=/app/config \
--name storagenode1 storjlabs/storagenode:latest
Node 1:
sudo su
docker run -d --restart unless-stopped \
--network host \
-e WALLET="xxx" \
-e EMAIL="xxx" \
-e ADDRESS="xxx:28961" \
-e STORAGE="xxTB" \
--mount type=bind,source="/volumeUSB1/usbshare/storjdbs1/",destination=/app/dbs \
--log-driver json-file \
--log-opt max-file=3 \
--name storagenode1 storjlabs/storagenode:latest \
--server.address=":28961" \
--console.address=":14011" \
--server.private-address="127.0.0.1:14021" \
--debug.addr=":6001" \
--storage2.database-dir=dbs \
--log.level=info \
--log.custom-level=piecestore=FATAL,collector=WARN \
--pieces.enable-lazy-filewalker=false \
--storage2.piece-scan-on-startup=false
Node 2:
sudo su
--network host \
-e WALLET="xxx" \
-e EMAIL="xxx" \
-e ADDRESS="xxx:28962" \
-e STORAGE="xxTB" \
--mount type=bind,source="/volumeUSB1/usbshare/storjdbs2/",destination=/app/dbs \
--server.address=":28962" \
--console.address=":14012" \
--server.private-address="127.0.0.1:14022" \
--debug.addr=":6002" \
--log.level=info \
Log files:
sudo su
docker logs storagenode1 2>&1
docker logs storagenode2 2>&1
docker logs watchtower 2>&1
docker logs storagenode1 2>&1 | grep "retain"
docker logs storagenode1 2>&1 | grep "pieces:trash"
# SL satellite:
docker logs storagenode1 2>&1 | grep "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"
# AP1 satellite:
docker logs storagenode1 2>&1 | grep "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"
# US1 satellite:
docker logs storagenode1 2>&1 | grep "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"
# EU1 satellite:
docker logs storagenode1 2>&1 | grep "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"
Path to logs:
# Path to log files:
sudo su
docker ps -a #get instance-id, the beggining of container-id
ls -l #get dirs and files details
# Synology:
sudo su
cd /volume1/@docker/containers/
/<containerID>/<containerID>-json.log
# Ubuntu:
sudo su
cd /var/lib/docker/containers/
Help manuals:
sudo su
docker exec -it storagenode1 ./storagenode setup --help
docker logs --help
Graceful Exit:
sudo su
# NODE 1:
docker exec -it storagenode1 /app/storagenode exit-satellite --config-dir /app/config --identity-dir /app/identity --server.private-address 127.0.0.1:14021
docker exec -it storagenode1 /app/storagenode exit-status --config-dir /app/config --identity-dir /app/identity --server.private-address 127.0.0.1:14021
# NODE 2:
docker exec -it storagenode2 /app/storagenode exit-satellite --config-dir /app/config --identity-dir /app/identity --server.private-address 127.0.0.1:14022
docker exec -it storagenode2 /app/storagenode exit-status --config-dir /app/config --identity-dir /app/identity --server.private-address 127.0.0.1:14022
Forget satellites:
sudo su
# Forget untrusted or exited satellites:
docker exec -it storagenode1 /app/storagenode forget-satellite \
--force \
12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB \
12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo \
--config-dir /app/config \
--identity-dir /app/identity \
docker exec -it storagenode2 /app/storagenode forget-satellite \
--force \
# check status:
docker exec -it storagenode1 /app/storagenode forget-satellite-status \
docker exec -it storagenode2 /app/storagenode forget-satellite-status \
# after Success status, wait 2 minutes and restart the node:
docker stop -t 300 storagenode1
docker restart -t 300 storagenode1
docker restart -t 300 storagenode2
If you change parameters in config.yaml, you only need to restart the node.
If you change parameters in run command, you have to recreate the container:
sudo su
docker rm storagenode1
docker run...
docker run...
