Disk usage discrepancy?
Hello,
I am running the node on a RPi, is there a suitable command on Linux that I could run ? The disk discrepancy still exists.
Regards, Ron
Are y[quote=“Ring_Zero, post:1161, topic:24715, full:true”]
[/quote]
So, high level, you need to restart the node and let it finish the used space filewalker. for each of four satellites. Which could take many days on a slow node.
Are you running straight docker, or docker compose, or something else?
i’m a docker compose person, To look at the logs try “docker logs storagenode | grep used”
if the most recent line in the file is “used-space-filewalker started” then it’s still running,
if the most recent line is “used-space-filewalker completed”, and you have four entries of it (one for each satellite), then it’s finished. (you can look at timestamps to figure out how long it ran)
If it has finished, and it’s still reporting inaccurate, then something is weird. probably fixable by bringing the node down and backup to kick off another round of filewalkers.
if it’s still running, let it finish.
You could also try looking in your /storage/temp and /storage/garbage directories. There shouldn’t be anything there any more (used in older versions of storj). I had one node which had like 10,000 small files in the temp folder, probably after some sort of crash.
Then perhaps you have a lazy filewalker failing, please check:
sudo docker logs storagenode 2>&1 | grep error | grep filewalker | tail
if so, then you need to disable the lazy mode, enable the badger cache and restart the node.
You may add these options after the image name to your docker run command:
You need to stop and remove the container, then run it back using your docker run command with all your parameters include changed ones to apply the change.
Then monitor when it would finish:
sudo docker logs storagenode -f 2>&1 | grep "\sused-space" | grep -E "started|finished"
You also should not have any untrusted satellites: How To Forget Untrusted Satellites
So finally after the automatic update logfiles went to the file now and here’s the logs. From what I can see it didn’t work once, also timewise earlier → but then it looks as it completed nicely.
What do you think?
grep "\used-space" /volume1/Storj2/node2new.log | grep -E "started|completed" | tail
2024-09-05T16:18:34Z	INFO	lazyfilewalker.used-space-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-09-05T16:37:46Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 2113405133568, "Total Pieces Content Size": 2111172414208}
2024-09-05T16:37:46Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW"}
2024-09-05T16:37:46Z	INFO	lazyfilewalker.used-space-filewalker	subprocess started	{"Process": "storagenode", "satelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW"}
2024-09-05T16:37:46Z	INFO	lazyfilewalker.used-space-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Process": "storagenode"}
2024-09-05T16:37:46Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Lazy File Walker": true, "Total Pieces Size": 224811008, "Total Pieces Content Size": 224761344}
2024-09-05T16:37:46Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-05T16:37:46Z	INFO	lazyfilewalker.used-space-filewalker	subprocess started	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-05T16:37:46Z	INFO	lazyfilewalker.used-space-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-09-05T16:38:28Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "Total Pieces Size": 1262812728832, "Total Pieces Content Size": 1262605037056}
and for errors:
grep error /volume1/Storj2/node2new.log | grep "used-space" | tail
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-05T13:36:41Z	ERROR	lazyfilewalker.used-space-filewalker	failed to start subprocess	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-05T13:36:41Z	ERROR	lazyfilewalker.used-space-filewalker	failed to start subprocess	{"Process": "storagenode", "satelliteID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "error": "context canceled"}
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-05T13:36:41Z	ERROR	lazyfilewalker.used-space-filewalker	failed to start subprocess	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-05T13:36:41Z	ERROR	pieces	used-space-filewalker failed	{"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
it should be
grep "\sused-space" /volume1/Storj2/node2new.log | grep -E "started|completed" | tail
The first \s is important - it allows to filter only useful messages, not all subprocesses.
When you see errors like these, it means that Filewalker was unable to calculate the space due to a timeout waiting for a response from the disk.
However, since you have completed them 3 hours later, I would assume that you restarted the node, and now it’s finishing the calculations. As far as I can see, two more satellites to go.
Perfect thanks for the clarification, from my side this now looks all perfect:
2024-09-05T13:36:47Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-05T16:14:22Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 5990491520170, "Total Pieces Content Size": 5973353694890}
2024-09-05T16:14:22Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-05T16:18:34Z	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 274433362944, "Total Pieces Content Size": 273879636480}
2024-09-05T16:18:34Z	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
I think somehow this node kind of fixed it over time with updates etc. For the Synology I think the trick was really to ‘Pin all Btrfs metadata to SSD cache’ … After that just a lot of catching up / deleting / etc. and now we’re fine. Also the tests are not happening anymore that helps for sure as well.
Thanks for the great support @Alexey :pray:
Why do you have 5 satellites?
The 118 Stefan Benten it’s decomisioned as far as I know.
https://forum.storj.io/t/how-to-forget-untrusted-satellites/23821?u=snorkel
https://forum.storj.io/t/satellite-info-address-id-blobs-folder-hex/17183?u=snorkel
Yeah good question - I also did the forget satelite command some weeks before, but it’s a very old node. Maybe it just runs through even though there’s no data any more for a long time?
You need to explicitly add this 118… satellite to the forget-satellite command with a --force flag.
Yeah I’ve done exactly that before, when you pointed me into that direction.
See logfiles here a bit further up:
Now that I read it again, I used his command:
docker exec -it storagenode ./storagenode forget-satellite --force 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB 12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo --config-dir config --identity-dir identity
So there were just two nodes in there to forget?
You again missed the 118 satellite, you just repeated for (I would assume) already removed satellites. The 118 much older and it is not included to the example command.
You need to execute
docker exec -it storagenode ./storagenode forget-satellite --force 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW --config-dir config --identity-dir identity
It’s me again Alexey :slight_smile:
So one of my nodes updated to “v1.114.6”.
Since it restarted, lots of IO going on:
The logs are spamming with this ‘unable to delete piece’ errors:
2024-10-16T12:49:24Z	WARN	collector	unable to delete piece	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "AFFBBFSFLA4BZZZ7AQR472EJPMNDRCDXON36RQ6FT52UWGDQLSTQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:126\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:350\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:329\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:375\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:111\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-10-16T12:49:24Z	WARN	collector	unable to delete piece	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "CSYHTUBJNYJTSNHCU3KEOUEI5I6YAVKKYDDEUYR2SFU3WAGU57HQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:126\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:350\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:329\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:375\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:111\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-10-16T12:49:24Z	WARN	collector	unable to delete piece	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "V4Z2RG6IMKZJC3ZLUARGEDGHIUNHIL36VKTUO4ISYCKXBIH74YRA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:126\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:350\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:329\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:375\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:111\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-10-16T12:49:24Z	WARN	collector	unable to delete piece	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "2MS26QBSC73BFCL7M4HBJ4MWWOVXAMPFPZNHBT4RZMTQU2LM45MA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:126\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:350\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:329\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:375\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:111\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-10-16T12:49:24Z	WARN	collector	unable to delete piece	{"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "LDEHNFQZAQIFCYTJOUIYULGEUUT4WQ54IWY57QP6L5RAQ7MQCAFA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:126\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:350\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:329\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:375\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:111\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
It is running for 2 days almost now… should I keep it going or restart?
Logfile is now 360 GB big so not so fast to find stuff in there :stuck_out_tongue:
Thanks.
Leave the node alone. Why would you want to restart i?
Feels like from previous performances it never runs so long (more than 24 hours) after an update. More in the 1 - 4 hours… And it really spams HUGE amount of unable to delete piece… I lieve it also running normally but felt very weird.
It’s unable to delete piece because that piece is already deleted. That “warning” shall be “info”, because there is nothing to warm about, it’s behavior by design. If you restart — it will still going to be “deleting” until it’s done.
Log rotate shall take care of large log files.
Yeah I know that it is common. But - it is now really spamming a lot.
And yes - will do log rotate next time, piped the output to a file for my previous issue … and just didnt do it yet :slight_smile:
On one of my nodes daily compressed (!) log was 2GB because of that. Compressed!
You may also reduce the log level using the custom log level for exactly this chore, see
Or reduce it temporary without restart:
I wonder who’s poking who?
Green on Brown or Brown on Green?
This is the million Storj dillema.
Hi there,
On one of my nodes I have noticed a significant difference between the reported disk usage and the actual disk usage. Here is what is reported:
…and here how much space the data are taking on the drive:
Any ideas how could I fix this problem and why so much data are consumed?
With kind regards,
Angelos Pitsos
