Disk usage discrepancy?
Done
12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs/s0/meta/hashtbl
12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs/s1/meta/hashtbl
Also, during the first launch, the logs on eu1 showed that an unclean shutdown was detected.
Another question unrelated to this node: has the BF generator been switched to the new backend yet? I’m getting 0 trash across all my nodes now.
I don’t have an information about BF yet.
Is it after you re-genrated hash tables?
Yes, re-generated few hours ago for s0 and s1
Then we need to wait when BF will start to come.
Looks like it’s work!
Did you disable the scan on startup? If yes, please enable it back, it might help too:
I got like 30% of data has probably trash not being picked up by boom filters for weeks now.
startup scan is on.
9.5TB used Disk space used 6.27TB.
All trash filewalkers have completed.
Did you saw this thread? AP1 and EU1 are sending Bloomfilters again after 4 weeks - #10 by littleskunk
I did not, thank you.
But aren’t boom filters automatic or are they still under development?
They are automatic, they just happened to break when there are big announcements/events (free acount abusers removed, vivint testing, minimum monthly fee, bankruptcy).
There is nothing to worry about. They will eventually be fixed some time next month and the constant deletes will continue (as always).
