I just got this hit…
10mths nothing wrong and upgrade to GUI and it goes kabluei
Something happened after Apple Update.
Any views welcomed!
Your node has been disqualified on 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs . If you have any questions regarding this please check our Node Operators thread on Storj forum.
2020-04-10T20:16:18.096+0800 INFO bandwidth Performing bandwidth usage rollups
2020-04-10T21:16:18.120+0800 INFO bandwidth Performing bandwidth usage rollups
2020-04-10T21:45:29.547+0800 INFO trust Scheduling next refresh {“after”: “6h54m47.151546598s”}
2020-04-10T22:16:18.156+0800 INFO bandwidth Performing bandwidth usage rollups
2020-04-10T22:16:19.235+0800 INFO version running on version v1.1.1
2020-04-10T23:16:18.131+0800 INFO bandwidth Performing bandwidth usage rollups
2020-04-10T23:23:00.931+0800 INFO Stop/Shutdown request received.
2020-04-10T23:23:48.927+0800 INFO Configuration loaded from: C:\Program Files\Storj\Storage Node\config.yaml
2020-04-10T23:23:49.119+0800 INFO Operator email: azrin@azrin.info
2020-04-10T23:23:49.119+0800 INFO operator wallet: 0x162C28E126A97D0009158Fbda0cA93E6e9CC13d0
2020-04-10T23:23:50.909+0800 INFO version running on version v1.1.1
2020-04-10T23:23:51.503+0800 INFO db.migration Database Version {“version”: 33}
2020-04-10T23:23:53.318+0800 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-04-10T23:23:54.400+0800 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-04-10T23:23:54.400+0800 INFO bandwidth Performing bandwidth usage rollups
2020-04-10T23:23:54.457+0800 INFO Node 125hQz4G3WRto2n8tJkjv4qiUoKeFrSSYspkZ818HwbVooHJJuY started
2020-04-10T23:23:54.457+0800 INFO Public server started on [::]:28967
2020-04-10T23:23:54.457+0800 INFO Private server started on 127.0.0.1:7778
2020-04-10T23:23:54.457+0800 INFO trust Scheduling next refresh {“after”: “8h38m21.666607766s”}
2020-04-10T23:23:54.828+0800 INFO version running on version v1.1.1
