After my first installation and a lot of test, one of the sattelite of my node is disqualified.
So, what will happend ?
What must i do ?
Thx
Thierry
What must i do ?
Thx
Thierry
Welcome to the forum! @thierry
How old is your node ?
Once disqualified there is nothing you can do with that satellite. Also its the node that gets disqualified not the satellite
My node works (finally) since 1 day
Indeed, the node is disqualified too.
And so, i repeat, what must id o ?
First you need to find out what disqualified your node so you can avoid making same mistake again. Which satellite shows your node as disqualified?
I think it’s because i tried first on another NAS and i didn’t transfer the data ;-(
The satelite is asia-east-1.tardigrade.io:7777
You nothing can do, if you didn’t transfer all data. Your node could be disqualified on other satellites soon.
If that happened, you need to create a new identity, sign it with a new authorization token and start from scratch.
Make sure you delete your old identity and data too before you start over
Ok, i started from scratch.
I cross my fingers.
Thanks for tour help.
Thierry
