i believe there is a failsafe that should stop the node from accepting more data if your disk is running out of space…
However personally i wouldn’t test it as it’s a fairly recent addition and if you do run out of space it can damage or destroy the storagenode, so not worth the risk…
but yeah you can reduce the allocated space, even if it’s already used… then it will just take a while to drop down to the new level of capacity you set the node to.
this happens because it will not “eject” the data, but simply not allow more ingress until the deletions take it under the amount set in the configuration of the node.
So basically it’s safe to use the space when it’s allocated to the storagenode, just keep in mind that if you choke the node / fill the storagenode hdd to max capacity with other data, it can damage or destroy the storagenode.
so the safest way is ofc doing it like suggest by the previous replies.
but still you would be able to choke the node of storage capacity to work with… it will always need some space for doing various operations, the recommended amount is 10% + the capacity of the storagenode.
depending on your filesystem or such you will be able to either partition or allocate a fixed amount for the storagenode in your host operating system, this way you would not be able to over fill the hdd so much that it kills the node…
ofc then you cannot borrow the space the node isn’t using … or it’s not very practical to do so, if running multiple partitions or such.
