Docker - Concurrent Connections
Hi,
Just looking to find if the concurrent connection setting is still in use and if so where can I change the value? Currently I run docker image with the flags specified no config file.
Thanks
Anton
you shouldn’t need much been running 16 with pretty high loads and no rejected.
but i’m still testing, now at 14… but no real traffic today for me…
