Hi there,
I needed to stop the storj node and when I try to restart it I basically can’t. It keeps restarting undefinitely. I try to run docker logs but is pointless as the container seems to not be starting at all.
I’m running storj on a RockPro64 and the command I use is:
docker run -d --restart unless-stopped -p 28967:28967 \
-p 127.0.0.1:14002:14002 \
-e WALLET="WALLET" \
-e EMAIL="EMAIL" \
-e ADDRESS="ADDRES.ddns.net:28967" \
-e BANDWIDTH="6TB" \
-e STORAGE="7TB" \
--mount type=bind,source="/home/user/storj/identity/storagenode",destination=/app/identity \
--mount type=bind,source="/mnt/data/Storj",destination=/app/config \
--name storagenode storjlabs/storagenode:arm
docker events&
shows this:
2020-12-01T19:51:20.044496824Z container create 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:20.256308081Z network connect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:20.982133709Z container start 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:28.021954216Z container die 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (exitCode=1, image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:28.310610338Z network disconnect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:28.575381773Z network connect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:29.266834562Z container start 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:36.406279535Z container die 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (exitCode=1, image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:36.823986991Z network disconnect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:37.065193615Z network connect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:37.777741667Z container start 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:44.904634899Z container die 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (exitCode=1, image=storjlabs/storagenode:arm, name=storagenode)
2020-12-01T19:51:45.246357366Z network disconnect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:45.537643328Z network connect 7c0f338d845e1eb5541c5f73b2078b8058abf1c337d7059ffc6fe651a7724aeb (container=2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b, name=bridge, type=bridge)
2020-12-01T19:51:46.246895914Z container start 2bce0c6fa6850ef56e1c73140b262570f67399fb955d14d849f8c0c9db7e176b (image=storjlabs/storagenode:arm, name=storagenode)
Any help would be much appreciated as I don’t want my node to be disqualified.
Thanks in advance.
