I Keep getting these docker codes when running new container I’ve deleted and re-downloaded container 100 times started completely over with new Identity, double checked firewall and I keep getting same codes.
2023-11-14 18:38:08 2023-11-15T01:38:08Z ERROR services unexpected shutdown of a runner {“process”: “storagenode”, “name”: “piecestore:monitor”, “error”: “piecestore monitor: error verifying location and/or readability of storage directory: node ID in file (1dBjfe6pBUUDvme3dWcsdMwqpvQJrUb5yrF8Wq49ypBXMvdBwf) does not match running node’s ID (1235D9wjJY9QAeaK8hQJ7rQjxVckR7ZJtXyhjjuvzKMtah9UQte)”, “errorVerbose”: “piecestore monitor: error verifying location and/or readability of storage directory: node ID in file (1dBjfe6pBUUDvme3dWcsdMwqpvQJrUb5yrF8Wq49ypBXMvdBwf) does not match running node’s ID (1235D9wjJY9QAeaK8hQJ7rQjxVckR7ZJtXyhjjuvzKMtah9UQte)\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:158\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:141\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-11-14 18:38:08 2023-11-15T01:38:08Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-11-14 18:38:08 2023-11-15T01:38:08Z INFO contact:service context cancelled {“process”: “storagenode”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2023-11-14 18:38:08 2023-11-15T01:38:08Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-11-14 18:38:08 2023-11-15T01:38:08Z INFO contact:service context cancelled {“process”: “storagenode”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2023-11-14 18:38:08 2023-11-15T01:38:08Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-11-14 18:38:08 2023-11-15T01:38:08Z ERROR nodestats:cache Get pricing-model/join date failed {“process”: “storagenode”, “error”: “context canceled”}
You mixed the data location from the one node (1dBjfe6pBUUDvme3dWcsdMwqpvQJrUb5yrF8Wq49ypBXMvdBwf) with the identity from the another node (1235D9wjJY9QAeaK8hQJ7rQjxVckR7ZJtXyhjjuvzKMtah9UQte).
Please fix your --mount option to point to the correct location of the identity for that data.
Now you need to use the correct external port, it must be different from the already used in your -p and -e ADDRESS options, i.e. -p 28968:28967/tcp -p 28968:28967/udp -e ADDRESS=your.domain.ddns:28968 and you should forward both 28968 UDP and TCP ports on your router to the 28968 TCP+UDP ports on your host with this storagenode.
