“2. Replace the <identity-dir> and <storage-dir> with your parameters.”
“My parameters” means the letter of the drive dedicated to Storj?
So if it’s Drive S how do I type it into the terminal? <(S:)>?
You are entering a path to the location of files.
In Windows it would be D:\Storj.
In Linux /home/storj/
Don’t keep the < and > in the path. You can search the forum for examples too.
