Docker Logs management
The log files of my nodes are getting larger and larger within Docker. How have you organized for space management? Do you “prune” logs sometimes?
You could try this…
Hello,
I personnaly configure the docker log driver : Configure logging drivers | Docker Documentation
I just create this file : /etc/docker/daemon.json
with the following content :
  "log-driver": "json-file",
  "log-opts": {
    "max-size": "10m",
    "max-file": "3"
it’s fine for me as I have docker only for for Storagenode and anyway 10m is enough for most cases.
I keep them all. Rotated on each node restart, so around every two weeks, then compressed with xz. This way they don’t take much space.
I am using log rotate with the following configuration:
sudo vi /etc/logrotate.d/storagenodes
/mnt/WD1003/logs/*.log
        weekly
        missingok
        rotate 4
        copytruncate
        compress
        notifempty
sudo logrotate -vf /etc/logrotate.d/
Plus the docker run command with the following parameters:
    --log-opt max-size=1g \
    --log-opt max-file=5 \
    --mount type=bind,source="/mnt/WD1003/logs",destination=/app/logs \
hello.
The file or log has a size of 22 GB, is it normal for a Linux Ubuntu system (odroid) located at. ./var/lib/docker/containers/f67a9e8d8e31df3926e9830ea5f24cb69becb3dc4186476a705ce99097fe0fdf/f67a9e8d8e31df3926e9830ea5f24cb69becb3dc4186476a705ce99097fe0fdf-json.log?"
it takes space on /dev/mmcblk1p2 29G 28G 434M 99% /
thanks for the idea what to do
Hello @Ingacz,
You have several options:
  1. Specify docker logs parameters in your docker run command before the image name
  1. Set logs level to less verbose like warn or error in the storagenode’s option --log.level=warn after the image name or in the config.yaml in your data location as a parameter
log.level: warn
  1. Configure redirect to the file and configure a logrotate like described above: Docker Logs management - #5 by Bivvo
Stop and remove the container, pull a new image and run your node back using all your parameters, include changed ones.
Please also check - do you have a stopped container, which could be an owner of this log:
docker ps -a
ok
thank you, the place has become available
I added the parameter to run docker
-p 28967:28967/tcp
-p 28967:28967/udp \
-p 14002:14002
-e WALLET=“------------------------”
-e EMAIL=“-----------------------------”
-e ADDRESS=“----------------:28967”
-e STORAGE=“8TB”
–log-opt max-size=1g
–log-opt max-file=5
–mount type=bind,source=“/mnt/root/storagenode”,destination=/app/identity
–mount type=bind,source=“/mnt/root/storage”,destination=/app/config
I hope everything will be alright
thx
