thank you for answer
3- i run this command
admin@SYNOLOGY_4K:/$ sudo docker run -it --rm --mount type=bind,source=/volume1/STORJ/DATA1/storage,destination=/data sstc/sqlite3 sqlite3 reputation.db
audit_reputation_score REAL NOT NULL,
disqualified TIMESTAMP,
updated_at TIMESTAMP NOT NULL, suspended TIMESTAMP, joined_at TIMESTAMP,
PRIMARY KEY (satellite_id)
CREATE TABLE versions (version int, commited_at text);
.exit
CREATE TABLE reputation (
satellite_id BLOB NOT NULL,
uptime_success_count INTEGER NOT NULL,
uptime_total_count INTEGER NOT NULL,
uptime_reputation_alpha REAL NOT NULL,
uptime_reputation_beta REAL NOT NULL,
uptime_reputation_score REAL NOT NULL,
audit_success_count INTEGER NOT NULL,
audit_total_count INTEGER NOT NULL,
audit_reputation_alpha REAL NOT NULL,
audit_reputation_beta REAL NOT NULL,
.exit
SQLite version 3.30.1 2019-10-10 20:19:45
Enter “.help” for usage hints.
sqlite> CREATE TABLE reputation (
LL,…> satellite_id BLOB NOT NUL
EGER NOT NULL, uptime_success_count INTE
ER NOT NULL, uptime_total_count INTEGE
REAL NOT NULL, uptime_reputation_alpha R
EAL NOT NULL, uptime_reputation_beta RE
REAL NOT NULL, uptime_reputation_score R
GER NOT NULL, audit_success_count INTEG
R NOT NULL, audit_total_count INTEGER
EAL NOT NULL, audit_reputation_alpha RE
AL NOT NULL, audit_reputation_beta REA
EAL NOT NULL, audit_reputation_score RE
…> disqualified TIMESTAMP,
NULL, suspended TIMESTAMP, joined_at TIMESTAMP, updated_at TIMESTAMP NOT
d) …> PRIMARY KEY (satellite_id
sqlite> CREATE TABLE versions (version int, commited_at text);
sqlite> .exit
4- I have an error with my node which seems to be disqualified
5- I check your logs after install my parameters of my node
admin@SYNOLOGY_4K : / $ sudo docker logs --tail 30 storagenode
storj.io/private/process.ExecWithCustomConfig:86
storj.io/private/process.ExecCustomDebug:68
main.main:320
runtime.main:203
2020-05-23T18:25:31.325Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2020-05-23T18:25:31.326Z INFO tracing disabled
2020-05-23T18:25:31.346Z INFO Operator email {“Address”: “mrbobiuss@hotmail.com”}
2020-05-23T18:25:31.346Z INFO Operator wallet {“Address”: “xxxxxxxxxxxxx”}
2020-05-23T18:25:32.220Z INFO db.migration.34 Add suspended field to satellites db
Error: Error creating tables for master database on storagenode: migrate: duplicate column name: suspended
storj.io/storj/private/migrate.SQL.Run:252
storj.io/storj/private/migrate.(*Migration).Run.func1:171
storj.io/storj/private/dbutil/txutil.withTxOnce:75
storj.io/storj/private/dbutil/txutil.WithTx:36
storj.io/storj/private/migrate.(*Migration).Run:170
storj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:294
main.cmdRun:180
storj.io/private/process.cleanup.func1.4:343
storj.io/private/process.cleanup.func1:361
github.com/spf13/cobra.(*Command).execute:840
github.com/spf13/cobra.(*Command).ExecuteC:945
github.com/spf13/cobra.(*Command).Execute:885
main.main:320
runtime.main:203
2020-05-23T18:26:34.713Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2020-05-23T18:26:34.714Z INFO tracing disabled
2020-05-23T18:26:34.734Z INFO Operator email {“Address”: “xxxxxxxxxx@hotmail.com”}
2020-05-23T18:26:34.734Z INFO Operator wallet {“Address”: “xxxxxxxxxxxxxxxxxxx”}
55/5000
Do you have a solution to help me restart my node
Thank you for you help.
Cdt
Christophe
