Docker node not starting after manual update
hi,
just updated my node manually:
now the docker logs:
019-09-06T06:21:31.012Z ERROR version running on not allowed/outdated version v0.17.0
2019-09-06T06:21:31.012Z FATAL outdated software version (v0.17.0), please update
2019-09-06T06:21:35.120Z INFO Configuration loaded from: /app/config/config.yaml
what I have done wrong?
thnaks
/////// forget the beta TAG
Are you using the :beta tag? What architecture are you on?
You may be having the same issue as mentioned here Pull of latest image failing
