I’m back with another issue I almost have this done and can start hosting. When I run the
docker pull storj labs/storagenode:beta
Command it says command not found. Can anyone help me with this one too?
try with “sudo docker pull storjlabs/storagenode:beta”
unless you haven’t installed docker yet, then you need to obviously install that first.
There are surely lots of instructions on google about how to install docker on a raspberry pi.
Follow the instructions here https://docs.docker.com/engine/install/debian/
Follow the link in the storj install docs
We have a special instruction for Raspberry PI:
