Docker restart alle 25s - Neue Node
Hi,
mein dockercontainer startet die ganze zeit neu.
Wies jemand was ich machen muss?
2024-07-01 11:52:48,956 INFO Set uid to user 0 succeeded
2024-07-01 11:52:48,963 INFO RPC interface ‘supervisor’ initialized
2024-07-01 11:52:48,963 INFO supervisord started with pid 1
2024-07-01 11:52:49,965 INFO spawned: ‘processes-exit-eventlistener’ with pid 11
2024-07-01 11:52:49,967 INFO spawned: ‘storagenode’ with pid 12
2024-07-01 11:52:49,968 INFO spawned: ‘storagenode-updater’ with pid 13
2024-07-01T11:52:49Z INFO Configuration loaded {“Process”: “storagenode-updater”, “Location”: “/app/config/config.yaml”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.address”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “contact.external-address”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “console.address”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet-features”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “healthcheck.details”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.private-address”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-disk-space”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.email”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-bandwidth”}
2024-07-01T11:52:49Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “healthcheck.enabled”}
2024-07-01T11:52:49Z INFO Anonymized tracing enabled {“Process”: “storagenode-updater”}
2024-07-01T11:52:49Z INFO Running on version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.105.4”}
2024-07-01T11:52:49Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2024-07-01T11:52:49Z INFO Configuration loaded {“Process”: “storagenode”, “Location”: “/app/config/config.yaml”}
2024-07-01T11:52:49Z INFO Anonymized tracing enabled {“Process”: “storagenode”}
2024-07-01T11:52:49Z INFO Operator email {“Process”: “storagenode”, “Address”: “kedceu@undeep.xyz”}
2024-07-01T11:52:49Z INFO Operator wallet {“Process”: “storagenode”, “Address”: “0xfD04a03ad7B8676aAF91824014caF1Dc7f64C276”}
2024-07-01T11:52:50Z INFO Current binary version {“Process”: “storagenode-updater”, “Service”: “storagenode”, “Version”: “v1.105.4”}
2024-07-01T11:52:50Z INFO Version is up to date {“Process”: “storagenode-updater”, “Service”: “storagenode”}
2024-07-01T11:52:50Z INFO Current binary version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.105.4”}
2024-07-01T11:52:50Z INFO Version is up to date {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”}
Willkommen im Forum.
Ich vermute mal das dies der log vom updater ist, nicht vom node selber.
den umgeleiteten log finden!, alle vorhandenen docker run commands anonymisieren und posten.
das setup/den pc beschreiben.
Es handelt sich um ein linux wo schon nodes aktiv laufen. Die Meldungen kommt direkt von docker container der neuen Node.
Ich habe 3 Versuche mit unterschiedlicher neuen ids durchgeführt.
Es tut mir leid,
Die informationen sind nicht ausreichend um auf fehlersuche zu gehen.
Als Tip:
Welches Linux?
Warum 3 identitys? Du brauchst eine für jede Node/hdd
Ist die letzte nach den anweisungen erstellt und verifiziert? Und wurde noch nie mit anderen daten benutzt. Daten und ids sind untrennbar verbunden und dürfen nicht ausgetauscht werden.
Sind die ports (welche ports nutzen die anderen nodes) richtig weitergeleitet, falls du welche doppelt nutzt könnte das den neustart erklären.
Viel Glück weiterhin.
Als Tip:
Welches Linux?
### Debian
### War ein Test, um herauszubekommen ob es sn dem Erstellungsprozess liegt
### Ja
### sind nicht doppelt
Ein Router neustart hat auch nichts gebracht.
Haben Sie das Protokoll in eine Datei umgeleitet? Denn im Auszug aus den Protokollen gibt es keine einzige Zeile aus dem Prozess storagenode.
