OK, thanks.
Here is a good chunk of the storj log, beginning from errors (it seems to largely repeat after this):
2023-07-30T01:39:39.132352423Z
2023-07-30T01:39:39.132407957Z 2023-07-30 01:39:39 (78.1 MB/s) - ‘/tmp/storagenode.zip’ saved [17483827/17483827]
2023-07-30T01:39:39.132415140Z
2023-07-30T01:39:39.377276711Z 2023-07-30 01:39:39,377 INFO RPC interface ‘supervisor’ initialized
2023-07-30T01:39:39.377323789Z 2023-07-30 01:39:39,377 INFO supervisord started with pid 1
2023-07-30T01:39:40.378845285Z 2023-07-30 01:39:40,378 INFO spawned: ‘processes-exit-eventlistener’ with pid 66
2023-07-30T01:39:40.379529806Z 2023-07-30 01:39:40,379 INFO spawned: ‘storagenode’ with pid 67
2023-07-30T01:39:40.380150847Z 2023-07-30 01:39:40,380 INFO spawned: ‘storagenode-updater’ with pid 68
2023-07-30T01:39:40.384324674Z 2023-07-30T01:39:40Z INFO Configuration loaded {“Process”: “storagenode-updater”, “Location”: “/app/config/config.yaml”}
2023-07-30T01:39:40.384334663Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “console.address”}
2023-07-30T01:39:40.384339311Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet-features”}
2023-07-30T01:39:40.384358958Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “contact.external-address”}
2023-07-30T01:39:40.384362785Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “healthcheck.details”}
2023-07-30T01:39:40.384375790Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.private-address”}
2023-07-30T01:39:40.384379547Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet”}
2023-07-30T01:39:40.384395426Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-bandwidth”}
2023-07-30T01:39:40.384399083Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-disk-space”}
2023-07-30T01:39:40.384402840Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.address”}
2023-07-30T01:39:40.384414322Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.email”}
2023-07-30T01:39:40.384418279Z 2023-07-30T01:39:40Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “healthcheck.enabled”}
2023-07-30T01:39:40.384431023Z 2023-07-30T01:39:40Z INFO Invalid configuration file value for key {“Process”: “storagenode-updater”, “Key”: “log.level”}
2023-07-30T01:39:40.384434880Z 2023-07-30T01:39:40Z INFO Anonymized tracing enabled {“Process”: “storagenode-updater”}
2023-07-30T01:39:40.384599929Z 2023-07-30T01:39:40Z INFO Running on version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.84.1”}
2023-07-30T01:39:40.384807096Z 2023-07-30T01:39:40Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2023-07-30T01:39:40.399641782Z 2023-07-30T01:39:40Z INFO Configuration loaded {“process”: “storagenode”, “Location”: “/app/config/config.yaml”}
2023-07-30T01:39:40.399773939Z 2023-07-30T01:39:40Z INFO Anonymized tracing enabled {“process”: “storagenode”}
2023-07-30T01:39:40.400462326Z 2023-07-30T01:39:40Z INFO Operator email {“process”: “storagenode”, “Address”: “XXXX”}
2023-07-30T01:39:40.400530243Z 2023-07-30T01:39:40Z INFO Operator wallet {“process”: “storagenode”, “Address”: “XXXX”}
2023-07-30T01:39:40.486206105Z 2023-07-30T01:39:40Z INFO server kernel support for server-side tcp fast open remains disabled. {“process”: “storagenode”}
2023-07-30T01:39:40.486289942Z 2023-07-30T01:39:40Z INFO server enable with: sysctl -w net.ipv4.tcp_fastopen=3 {“process”: “storagenode”}
2023-07-30T01:39:40.540147132Z 2023-07-30T01:39:40Z INFO Current binary version {“Process”: “storagenode-updater”, “Service”: “storagenode”, “Version”: “v1.84.1”}
2023-07-30T01:39:40.540161559Z 2023-07-30T01:39:40Z INFO Version is up to date {“Process”: “storagenode-updater”, “Service”: “storagenode”}
2023-07-30T01:39:40.542689307Z 2023-07-30T01:39:40Z INFO Current binary version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.84.1”}
2023-07-30T01:39:40.542699075Z 2023-07-30T01:39:40Z INFO Version is up to date {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”}
2023-07-30T01:39:40.662178830Z 2023-07-30T01:39:40Z INFO Telemetry enabled {“process”: “storagenode”, “instance ID”: “12jQvhZ1fGvLei12oWHwkHjye2F7odJBeEAHuSzjv8fSQpTVZvE”}
2023-07-30T01:39:40.662219607Z 2023-07-30T01:39:40Z INFO Event collection enabled {“process”: “storagenode”, “instance ID”: “12jQvhZ1fGvLei12oWHwkHjye2F7odJBeEAHuSzjv8fSQpTVZvE”}
2023-07-30T01:39:40.674295773Z 2023-07-30T01:39:40Z INFO db.migration Database Version {“process”: “storagenode”, “version”: 54}
2023-07-30T01:39:41.067999305Z 2023-07-30T01:39:41Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock. {“process”: “storagenode”}
2023-07-30T01:39:41.776910347Z 2023-07-30T01:39:41Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock. {“process”: “storagenode”}
2023-07-30T01:39:41.777022838Z 2023-07-30 01:39:41,776 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-07-30T01:39:41.777103769Z 2023-07-30 01:39:41,777 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-07-30T01:39:41.777145758Z 2023-07-30 01:39:41,777 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-07-30T01:39:41.777260582Z 2023-07-30T01:39:41Z INFO bandwidth Performing bandwidth usage rollups {“process”: “storagenode”}
2023-07-30T01:39:41.777266463Z 2023-07-30T01:39:41Z INFO trust Scheduling next refresh {“process”: “storagenode”, “after”: “4h50m9.83735722s”}
2023-07-30T01:39:41.777283355Z 2023-07-30T01:39:41Z INFO Node 12jQvhZ1fGvLei12oWHwkHjye2F7odJBeEAHuSzjv8fSQpTVZvE started {“process”: “storagenode”}
2023-07-30T01:39:41.777287212Z 2023-07-30T01:39:41Z INFO Public server started on [::]:28967 {“process”: “storagenode”}
2023-07-30T01:39:41.777290378Z 2023-07-30T01:39:41Z INFO Private server started on 127.0.0.1:7778 {“process”: “storagenode”}
2023-07-30T01:39:41.777302471Z 2023-07-30T01:39:41Z INFO pieces:trash emptying trash started {“process”: “storagenode”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”}
2023-07-30T01:39:41.777306198Z 2023-07-30T01:39:41Z INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See UDP Receive Buffer Size · quic-go/quic-go Wiki · GitHub for details. {“process”: “storagenode”}
2023-07-30T01:39:41.777332206Z 2023-07-30T01:39:41Z INFO pieces:trash emptying trash started {“process”: “storagenode”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2023-07-30T01:39:41.777343588Z 2023-07-30T01:39:41Z INFO pieces:trash emptying trash started {“process”: “storagenode”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2023-07-30T01:39:41.777361431Z 2023-07-30T01:39:41Z INFO pieces:trash emptying trash started {“process”: “storagenode”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2023-07-30T01:39:41.777386157Z 2023-07-30T01:39:41Z INFO pieces:trash emptying trash started {“process”: “storagenode”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”}
2023-07-30T01:39:41.777407207Z 2023-07-30T01:39:41Z INFO pieces:trash emptying trash started {“process”: “storagenode”, “Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”}
2023-07-30T01:39:41.984051257Z 2023-07-30T01:39:41Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 1, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-07-30T01:39:42.077882633Z 2023-07-30T01:39:42Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 1, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-07-30T01:39:42.236691526Z 2023-07-30T01:39:42Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 1, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-07-30T01:39:42.299940572Z 2023-07-30T01:39:42Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-07-30T01:39:42.484208463Z 2023-07-30T01:39:42Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “attempts”: 1, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-07-30T01:39:42.835737465Z 2023-07-30T01:39:42Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 1, “error”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert”, “errorVerbose”: “ping satellite: failed to ping storage node, your node indicated error code: 0, rpc: tcp connector failed: rpc: tls peer certificate verification: not signed by any CA in the whitelist: CA cert\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:209\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-07-30T01:39:43.179701729Z 2023-07-30T01:39:43Z ERROR contact:service ping satellite failed {“process”: “storagenode”, “Satellite ID”:
Here is a chunk of the setup log:
2023-07-30T01:39:24.469245241Z
2023-07-30T01:39:24.469280307Z 2023-07-30 01:39:24 (46.6 MB/s) - ‘/tmp/storagenode.zip’ saved [17483827/17483827]
2023-07-30T01:39:24.469285166Z
2023-07-30T01:39:24.692970660Z 2023-07-30 01:39:24,692 INFO RPC interface ‘supervisor’ initialized
2023-07-30T01:39:24.693028638Z 2023-07-30 01:39:24,692 INFO supervisord started with pid 6
2023-07-30T01:39:25.695095444Z 2023-07-30 01:39:25,694 INFO spawned: ‘processes-exit-eventlistener’ with pid 66
2023-07-30T01:39:25.695667404Z 2023-07-30 01:39:25,695 INFO spawned: ‘storagenode’ with pid 67
2023-07-30T01:39:25.696160056Z 2023-07-30 01:39:25,696 INFO spawned: ‘storagenode-updater’ with pid 68
2023-07-30T01:39:25.701082792Z 2023-07-30T01:39:25Z INFO Configuration loaded {“Process”: “storagenode-updater”, “Location”: “/app/config/config.yaml”}
2023-07-30T01:39:25.701098862Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “console.address”}
2023-07-30T01:39:25.701104263Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-disk-space”}
2023-07-30T01:39:25.701126164Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.private-address”}
2023-07-30T01:39:25.701130061Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.address”}
2023-07-30T01:39:25.701140991Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.email”}
2023-07-30T01:39:25.701145149Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “healthcheck.enabled”}
2023-07-30T01:39:25.701155689Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-bandwidth”}
2023-07-30T01:39:25.701159316Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “contact.external-address”}
2023-07-30T01:39:25.701162842Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “healthcheck.details”}
2023-07-30T01:39:25.701172901Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet”}
2023-07-30T01:39:25.701176598Z 2023-07-30T01:39:25Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet-features”}
2023-07-30T01:39:25.701186997Z 2023-07-30T01:39:25Z INFO Invalid configuration file value for key {“Process”: “storagenode-updater”, “Key”: “log.output”}
2023-07-30T01:39:25.701190804Z 2023-07-30T01:39:25Z INFO Invalid configuration file value for key {“Process”: “storagenode-updater”, “Key”: “log.stack”}
2023-07-30T01:39:25.701200743Z 2023-07-30T01:39:25Z INFO Invalid configuration file value for key {“Process”: “storagenode-updater”, “Key”: “log.development”}
2023-07-30T01:39:25.701204460Z 2023-07-30T01:39:25Z INFO Invalid configuration file value for key {“Process”: “storagenode-updater”, “Key”: “log.encoding”}
2023-07-30T01:39:25.701208487Z 2023-07-30T01:39:25Z INFO Invalid configuration file value for key {“Process”: “storagenode-updater”, “Key”: “log.level”}
2023-07-30T01:39:25.701219809Z 2023-07-30T01:39:25Z INFO Anonymized tracing enabled {“Process”: “storagenode-updater”}
2023-07-30T01:39:25.701287545Z 2023-07-30T01:39:25Z INFO Running on version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.84.1”}
2023-07-30T01:39:25.701420684Z 2023-07-30T01:39:25Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2023-07-30T01:39:25.717195689Z 2023-07-30T01:39:25Z INFO Configuration loaded {“process”: “storagenode”, “Location”: “/app/config/config.yaml”}
2023-07-30T01:39:25.717338386Z 2023-07-30T01:39:25Z INFO Anonymized tracing enabled {“process”: “storagenode”}
2023-07-30T01:39:25.718070034Z 2023-07-30T01:39:25Z WARN Operator email address isn’t specified. {“process”: “storagenode”}
2023-07-30T01:39:25.718078460Z 2023-07-30T01:39:25Z ERROR Invalid configuration. {“process”: “storagenode”, “error”: “operator wallet address isn’t specified”}
2023-07-30T01:39:25.718094009Z Error: operator wallet address isn’t specified
2023-07-30T01:39:25.718638247Z 2023-07-30 01:39:25,718 INFO exited: storagenode (exit status 1; not expected)
2023-07-30T01:39:25.843823293Z 2023-07-30T01:39:25Z INFO Current binary version {“Process”: “storagenode-updater”, “Service”: “storagenode”, “Version”: “v1.84.1”}
2023-07-30T01:39:25.843862357Z 2023-07-30T01:39:25Z INFO Version is up to date {“Process”: “storagenode-updater”, “Service”: “storagenode”}
2023-07-30T01:39:25.846379124Z 2023-07-30T01:39:25Z INFO Current binary version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.84.1”}
2023-07-30T01:39:25.846397909Z 2023-07-30T01:39:25Z INFO Version is up to date {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”}
2023-07-30T01:39:26.848027287Z 2023-07-30 01:39:26,847 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-07-30T01:39:26.849084555Z 2023-07-30 01:39:26,848 INFO spawned: ‘storagenode’ with pid 104
2023-07-30T01:39:26.849214548Z 2023-07-30 01:39:26,849 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-07-30T01:39:26.867283923Z 2023-07-30T01:39:26Z INFO Configuration loaded {“process”: “storagenode”, “Location”: “/app/config/config.yaml”}
2023-07-30T01:39:26.867331402Z 2023-07-30T01:39:26Z INFO Anonymized tracing enabled {“process”: “storagenode”}
Hard to know how much to post, so sorry about all this!
Eumaios send his thanks!
