From what I’ve seen in docs and examples, only whole numbers are used in the STORAGE variable for the docker run command. Is the numeric portion required to be a whole number? For example, an SNO wants to allow Storj to use more space - from 5TB to 5.5TB, which of the following is most appropriate?
Same story here, but different tests.
On small nodes, i was trying to leave 10% of free space.
It does not matter will i set 900Gb or 880Gb or 870Gb, they all have only ~30Gb of free space, means using 900Gb, no matter what i set up.
On bigger nodes this is not so important, but lets say on 1Tb node you can have 3% of empty space or ~14% of empty space, but no way to have 10% or a bit less.
