Earnings calculator (Detailed earnings info and health status of your node, including vetting progress and garbage collection status)
yes, I updated to the latest version of the script.
A few days ago everything was fine, but after the node was autoupdated to v1.104.5 I get the above error. I guess it has something to do with reorganization of the DB such that things you rely on in the script are no longer there. Did not debug yet but will do when I can find time.
Thanks for your continuing efforts on this wonderful tool :smile:
It definitely works on that version and there were no DB changes between 1.104.1 and 1.104.5. The error you get also doesn’t make much sense as it’s a syntax error. Kind of suggests your copy of the script has been altered. Please redownload the latest version of the script. It should work.
Thanks @BrightSilence
but sorry to say, still not working. Something seems to be wrong in the query string syntax (so it is not the call syntax that is causing the error but the DB operations done by the query string). I still don’t know exactly which part it is, will keep looking into it.
If you freshly download from github-raw, does it work for you?
This topic would be littered with complaints if that didn’t work. The strange thing is that syntax error suggests it’s an invalid query. That shouldn’t even depend on the databases.
Yes, it works for me and for many others too.
Maybe you can make it print the query string, see if there is anything obvious that is wrong with the query as its generated on your system?
    SELECT x.satellite_name satellite
    ,COALESCE(a.put_total,0) put_total
    ,COALESCE(a.get_total,0) get_total
    ,COALESCE(a.get_audit_total,0) get_audit_total
    ,COALESCE(a.get_repair_total,0) get_repair_total
    ,COALESCE(a.put_repair_total,0) put_repair_total
    ,COALESCE(c.bh_total,0) bh_total
    ,COALESCE(b.total,0) disk_total
    ,COALESCE(p.bh_payout,0) bh_payout
    ,COALESCE(p.get_payout,0) get_payout
    ,COALESCE(p.get_repair_payout,0) get_repair_payout
    ,COALESCE(p.get_audit_payout,0) get_audit_payout
    ,COALESCE(d.rep_status,'') rep_status
    ,COALESCE(d.vet_count,0) vet_count
    ,COALESCE(d.uptime_score,0) uptime_score
    ,COALESCE(d.audit_score,0) audit_score
    ,COALESCE(d.audit_suspension_score,0) audit_suspension_score
    ,COALESCE(d.joined_at, '') sat_start_dt
    ,COALESCE(f.surge_percent, 100) surge_percent
    ,COALESCE(g.held_so_far,0) held_so_far
    ,COALESCE(g.disp_so_far,0) disp_so_far
    ,COALESCE(g.postponed_so_far, 0) postponed_so_far
    ,COALESCE(f.disposed,0) disposed
    ,COALESCE(f.payout,0) payout
    ,COALESCE(f.paid_out,0) paid_out
    ,CASE WHEN f.payout > f.paid_out THEN f.payout - f.paid_out ELSE 0 END postponed
    ,CASE WHEN f.paid_out > f.payout THEN f.paid_out - f.payout ELSE 0 END paid_prev_month
    ,COALESCE(h.receipt, '') receipt
    ,COALESCE(h.receipt_amount,0) receipt_amount
    ,COALESCE(1+strftime('%m', date('2024-05-01')) - strftime('%m', date(d.joined_at)) +
     (strftime('%Y', date('2024-05-01')) - strftime('%Y', date(d.joined_at))) * 12, 0) AS month_nr
    ,COALESCE(SUBSTR(f.pay_stat, 1, LENGTH(f.pay_stat)-2), '') AS pay_status
    ,COALESCE(c.seconds_bh_included,2592000) seconds_bh_included --Assume full month if NULL. This basically only happens when no storage has been reported by the satellite yet.
    ,COALESCE(c.disk_last_report,0) disk_last_report
    FROM (
    SELECT DISTINCT active_sat.satellite_id,
                       CASE
                    	   WHEN sat.address IS NOT NULL THEN sat.address
                           WHEN hex(satellite_id) = '84A74C2CD43C5BA76535E1F42F5DF7C287ED68D33522782F4AFABFDB40000000' THEN 'ap1.storj.io:7777*'
                           WHEN hex(satellite_id) = 'AF2C42003EFC826AB4361F73F9D890942146FE0EBE806786F8E7190800000000' THEN 'eu1.storj.io:7777*'
                           WHEN hex(satellite_id) = 'F474535A19DB00DB4F8071A1BE6C2551F4DED6A6E38F0818C68C68D000000000' THEN 'europe-north-1.tardigrade.io:7777*'
                           WHEN hex(satellite_id) = '7B2DE9D72C2E935F1918C058CAAF8ED00F0581639008707317FF1BD000000000' THEN 'saltlake.tardigrade.io:7777*'
                           WHEN hex(satellite_id) = 'A28B4F04E10BAE85D67F4C6CB82BF8D4C0F0F47A8EA72627524DEB6EC0000000' THEN 'us1.storj.io:7777*'
                           WHEN hex(satellite_id) = '04489F5245DED48D2A8AC8FB5F5CD1C6A638F7C6E75EFD800EF2D72000000000' THEN 'us2.storj.io:7777*'
                           WHEN hex(satellite_id) = '004AE89E970E703DF42BA4AB1416A3B30B7E1D8E14AA0E558F7EE26800000000' THEN 'satellite.stefan-benten.de:7777* (shut down)'
                           ELSE '-UNKNOWN-'
                       END satellite_name,
                       sat.added_at AS satellite_added_at
                FROM (
                   SELECT satellite_id, interval_start FROM bandwidth_usage WHERE interval_start >= '2024-05-01' AND interval_start < '2024-06-01'
                   UNION
                   SELECT satellite_id, timestamp interval_start FROM su.storage_usage WHERE interval_start >= '2024-05-01' AND interval_start < '2024-06-01'
                ) active_sat
                LEFT JOIN satellites sat
                ON active_sat.satellite_id = sat.node_id
) x
    LEFT JOIN
    psu.piece_space_used b
    ON x.satellite_id = b.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      ,SUM(put_total) put_total
      ,SUM(get_total) get_total
      ,SUM(get_audit_total) get_audit_total
      ,SUM(get_repair_total) get_repair_total
      ,SUM(put_repair_total) put_repair_total
      FROM bw.bandwidth_usage a
      GROUP BY satellite_id
    ) a
    ON x.satellite_id = a.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      ,SUM(at_rest_total) bh_total
      ,strftime('%s', max(edt)) - strftime('%s', min(sdt)) seconds_bh_included
      ,max(last_window_bh)*3600 / (strftime('%s', max(edt)) - strftime('%s', max(sdt))) disk_last_report
      FROM (SELECT timestamp interval_start, satellite_id, at_rest_total, interval_end_time edt,
            (SELECT interval_end_time
             FROM su.storage_usage su2
             WHERE su1.satellite_id = su2.satellite_id
             AND su2.timestamp < su1.timestamp
             AND su2.interval_end_time <> '0001-01-01 00:00:00+00:00' /* ignore incomplete records */
             ORDER BY timestamp DESC
             LIMIT 1) sdt,
             LAST_VALUE(at_rest_total) OVER
            	(PARTITION BY satellite_id ORDER BY interval_end_time
            	 RANGE BETWEEN UNBOUNDED PRECEDING AND UNBOUNDED FOLLOWING) last_window_bh
            FROM su.storage_usage su1
            WHERE su1.interval_end_time <> '0001-01-01 00:00:00+00:00' /* ignore incomplete records */)
    ) c
    ON x.satellite_id = c.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      ,CASE WHEN disqualified_at IS NOT NULL THEN 'Disqualified @ ' || datetime(disqualified_at)
            WHEN suspended_at IS NOT NULL THEN 'Suspended Audits @ ' || datetime(suspended_at)
            WHEN offline_suspended_at IS NOT NULL THEN 'Suspended Downt. @ ' || datetime(offline_suspended_at)
            WHEN offline_under_review_at IS NOT NULL THEN 'Downtime review @ ' || datetime(offline_under_review_at)
            WHEN audit_success_count < 100 THEN 'Vetting '
            WHEN audit_reputation_score < 0.998 OR audit_unknown_reputation_score < 0.998 THEN 'WARN: Audits failing'
            WHEN online_score < 0.98 THEN 'WARN: Downtime high'
            ELSE 'OK' END AS rep_status
      ,date(joined_at) AS joined_at
      ,MIN(audit_success_count, 100) AS vet_count
      ,100.0*online_score AS uptime_score
      ,((1-audit_reputation_score)*100.0)/(1.0-0.96) AS audit_score
      ,((1-audit_unknown_reputation_score)*100.0)/(1.0-0.6) AS audit_suspension_score
      FROM r.reputation
    ) d
    ON x.satellite_id = d.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      , CASE WHEN INSTR(codes, 'D') > 0 THEN 'Disqualified, '          ELSE '' END
      ||CASE WHEN INSTR(codes, 'X') > 0 THEN 'Graceful Exit, '         ELSE '' END
      ||CASE WHEN INSTR(codes, 'S') > 0 THEN 'Sanctioned Country, '    ELSE '' END
      ||CASE WHEN INSTR(codes, 'T') > 0 THEN 'Tax form 1099 missing, ' ELSE '' END AS pay_stat
      ,CASE WHEN surge_percent = 0 THEN 100 ELSE surge_percent END AS surge_percent
      ,disposed/1000000.0 disposed
      ,paid/1000000.0 payout
      ,distributed/1000000.0 paid_out
      FROM h.paystubs
      WHERE period = '2024-05'
    ) f
    ON x.satellite_id = f.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      ,COUNT(period) n_months_prec
      ,MAX(period) last_period
      ,SUM(held)/1000000.0 held_so_far
      ,SUM(disposed)/1000000.0 disp_so_far
      ,(SUM(paid)-SUM(distributed))/1000000.0 postponed_so_far
      FROM h.paystubs
      WHERE period < '2024-05'
    ) g
    ON x.satellite_id = g.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      , CASE
          WHEN SUBSTR(receipt, 1, 4) = 'eth:' THEN 'https://etherscan.io/tx/'||SUBSTR(receipt, 5)
          WHEN SUBSTR(receipt, 1, 7) = 'zksync:' THEN 'https://zkscan.io/explorer/transactions/'||SUBSTR(receipt, 8)
        END receipt
      , amount/1000000.0 AS receipt_amount
      FROM h.payments
    ) h
    ON x.satellite_id = h.satellite_id
    LEFT JOIN (
      SELECT
      satellite_id
      ,disk_space_price/100.0 bh_payout
      ,egress_bandwidth_price/100.0 get_payout
      ,repair_bandwidth_price/100.0 get_repair_payout
      ,audit_bandwidth_price/100.0 get_audit_payout
      FROM p.pricing
    ) p
    ON x.satellite_id = p.satellite_id
    ORDER BY CAST(COALESCE(x.satellite_added_at, '9999-12-31') AS date), x.satellite_name;
Can you put the code in a code block so the forum doesn’t mess up the format?
Code here
thanks @BrightSilence, I put the block as code. Maybe you can give it a look to find where the error occurs
It is still there on several of my nodes with different versions of ubuntu under the hood.
It doesn’t have any syntax errors from what I can tell. I’m not sure where else to look. If you want you can zip up satellites.db, bandwidth.db, storage_usage.db, piece_spaced_used.db, reputation.db, heldamount.db and pricing.db and send them to me. I suggest using Storj and PM me the link. :wink:
I’d be happy to have a look. In the mean time, which python version are you using?
python --version or python3 --version
@BrightSilence thank you.
Python 3.6.9
Thanks for the offer to work on my .db files, I will try a few things myself first and if needed I will send you those. Thanks again.
@champmine18 I’m facing the same issue. Did you solve that sintaxe error?
I’m working on a new update to include an indicator whether GC is running on your node as well as the last processed folder as an indication of progress. This requires a little more testing on my end still, but here’s a sneak peek.
The date is the date the bloom filter was created.
Ps. Unlike other scripts I saw posted, this is not dependent on logs and therefor doesn’t run into issues when logs are removed or rotated. It uses the progress stored in garbage_collection_filewalker_progress.db, so it should be more reliable.
Can this be done for startup piece scan as well?
Unfortunately only GC progress is stored in a db. I’d be happy to add more if Storj ever stores info regarding those other processes in the db’s. But they did this specifically to implement the resume function, which exists for GC only, I believe.
This feature is now live. Please report any issues you encounter with it.
Changelog
v14.1.0 - Garbage collection progress
  • Add feature to show garbage collection progress
So this is basically saying my bloomfilter is out of date, this is the most recent one, make sure I get a new one soon for this satelitte?
(GC @ Folder:is Date:2024-08-22)
They are always a few days old. It takes some time to make a db snapshot and create the bloom filters. This is normal.
I just looked at one node I restarted and found it processing a bloom filter from the SLC satellite, and as soon as it finished, processing another one generated by SLC… I guess I have a backlog to work through.
You may see that backlog in the storage/retain folder (docker) or "%ProgramFiles%\Storj\Storage Node\retain\" (Windows service).
my retain dir is in my config dir (docker), but it’s empty, so that means there are none pending?
I don’t see a retain folder at all (docker/linux) so either I’m all good or looking in the wrong place!
