Earnings very low
I currently run a Node on a WIN 10 PC with 16GB RAM and a AMD Athlon 5150 APU with Radeon R3 1.60Ghz the node is 4.5TB i have an 100Mbits Dowlaod and 25Mbits upload speed 16.33 TB*h but only 71Gb bandwith used and only: Current Month earning: 0.33$ Total earned:0$ total held:0
plese help
Hi there,
If you are currently holding 71 GB of Storj data then your monthly earnings of $0.33 seems normal. It will take a long time to fill 4.5TB. For reference, I have one node running for 5 months that is now using 620GB and might earn $3 this month.
I have been running for a couple years and so far storing about 17 TiB - earning about $50/mo in tokens. It takes a very long time.
Welcome to the Forum @EnesBaraa !
You might look at the Earnings Estimator by BrightSilence to see how this will progress over time
Also you can see storj success rate to see how far vetted you are
Well how many audits I’m pretty sure the earnings estimator script says vetting %
