El nodo inicia y se desconecta de inmediato
Buenos días, uso Windows GUI 1.6.4, se fue la luz y al iniciar el equipo el Nodo se conecta y se apaga de inmediato.
2020-07-01T07:04:21.010+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-01T07:04:21.482+0200 INFO Operator email {“Address”: “servidor01storj@gmail.com”}
2020-07-01T07:04:21.483+0200 INFO Operator wallet {“Address”: “0x671850235e239D4294b7a233576Efb99e876e2DC”}
2020-07-01T07:04:24.158+0200 INFO Telemetry enabled
2020-07-01T07:04:27.712+0200 INFO db.migration Database Created {“version”: 42}
2020-07-01T07:04:28.422+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-01T07:04:29.363+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-01T07:04:29.369+0200 INFO Node 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp started
2020-07-01T07:04:29.370+0200 INFO Public server started on [::]:28967
2020-07-01T07:04:29.370+0200 INFO Private server started on 127.0.0.1:7778
2020-07-01T07:04:29.371+0200 INFO trust Scheduling next refresh {“after”: “2h37m21.1773903s”}
2020-07-01T07:04:29.371+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-01T07:04:31.923+0200 ERROR nodestats:cache Get pricing-model/join date failed {“error”: “heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp; heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp; heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp; heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp; heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp; heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp”, “errorVerbose”: “group:\n— heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp\n\tstorj.io/storj/storagenode/heldamount.(*Service).GetAllPaystubs:135\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:78\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:233\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:77\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp\n\tstorj.io/storj/storagenode/heldamount.(*Service).GetAllPaystubs:135\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:78\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:233\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:77\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp\n\tstorj.io/storj/storagenode/heldamount.(*Service).GetAllPaystubs:135\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:78\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:233\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:77\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp\n\tstorj.io/storj/storagenode/heldamount.(*Service).GetAllPaystubs:135\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:78\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:233\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:77\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp\n\tstorj.io/storj/storagenode/heldamount.(*Service).GetAllPaystubs:135\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:78\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:233\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:77\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— heldamount service error: node not found: 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp\n\tstorj.io/storj/storagenode/heldamount.(*Service).GetAllPaystubs:135\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:78\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:233\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:77\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-01T07:08:04.192+0200 INFO Stop/Shutdown request received.
2020-07-01T07:08:05.152+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Power Shell:
PS C:\WINDOWS\system32> Get-Service storagenode*
Status Name DisplayName
Running storagenode Storj V3 Storage Node
Running storagenode-upd… Storj V3 Storage Node Updater
Stopped storagenode Storj V3 Storage Node
PS C:\WINDOWS\system32> (sls BEGIN $env:AppData\Storj\Identity\storagenode\ca.cert).count
(sls BEGIN $env:AppData\Storj\Identity\storagenode\identity.cert).count
2
3
No se que puede ser.
Gracias,
I think that when the electric current failed, the database was broken, the last log:
2020-07-03T09:02:03.964+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-03T09:02:04.090+0200 INFO Operator email {“Address”: “servidor01storj@gmail.com”}
2020-07-03T09:02:04.091+0200 INFO Operator wallet {“Address”: “0x671850235e239D4294b7a233576Efb99e876e2DC”}
2020-07-03T09:02:05.072+0200 INFO Telemetry enabled
2020-07-03T09:02:05.143+0200 INFO db.migration Database Version {“version”: 42}
2020-07-03T09:02:06.126+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-03T09:02:07.058+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-03T09:02:07.059+0200 INFO trust Scheduling next refresh {“after”: “4h41m3.414351887s”}
2020-07-03T09:02:07.059+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-03T09:02:07.064+0200 INFO Node 12rKzDaH3gceBk1Q7tQKyaPwBwJXNSnXwpfd4LeQNYpW2KwHcAp started
2020-07-03T09:02:07.064+0200 INFO Public server started on [::]:28967
2020-07-03T09:02:07.064+0200 INFO Private server started on 127.0.0.1:7778
2020-07-03T09:02:09.270+0200 INFO piecestore upload started {“Piece ID”: “PITM46FML6AIBOTW5XMH7X3PVIEMCQQX4W3IBUJBSITKVWBVVUUA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT”, “Available Space”: 1582174124800}
2020-07-03T09:02:12.609+0200 INFO piecestore upload canceled {“Piece ID”: “PITM46FML6AIBOTW5XMH7X3PVIEMCQQX4W3IBUJBSITKVWBVVUUA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT”}
2020-07-03T09:02:12.611+0200 ERROR piecestore:cache error getting current space used calculation: {“error”: “GetFileInformationByHandle d:\STORJ\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\fs/fkk2fkipbsfxr2l3yrmqqnbmx3bkjeih5r4hvzzfgx6azuin7q.sj1: The file or directory is corrupted and unreadable.; GetFileInformationByHandle d:\STORJ\blobs\pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa\3q/lejo53ggcmbudjzhctkd3jzxuj7ed63r5kagxwpqzdtqpkglna.sj1: The file or directory is corrupted and unreadable.; GetFileInformationByHandle d:\STORJ\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\av/4ko73nv426jw3uxqxcmjqp4okgntjbh6vtqmznznyxfdgzdm4q.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “group:\n— GetFileInformationByHandle d:\STORJ\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\fs/fkk2fkipbsfxr2l3yrmqqnbmx3bkjeih5r4hvzzfgx6azuin7q.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:714\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:652\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:612\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:258\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:468\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:633\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:54\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— GetFileInformationByHandle d:\STORJ\blobs\pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa\3q/lejo53ggcmbudjzhctkd3jzxuj7ed63r5kagxwpqzdtqpkglna.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:714\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:652\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:612\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:258\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:468\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:633\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:54\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— GetFileInformationByHandle d:\STORJ\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\av/4ko73nv426jw3uxqxcmjqp4okgntjbh6vtqmznznyxfdgzdm4q.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:714\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:652\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:612\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:258\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:468\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:633\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:54\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-03T09:02:13.629+0200 FATAL Unrecoverable error {“error”: “GetFileInformationByHandle d:\STORJ\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\fs/fkk2fkipbsfxr2l3yrmqqnbmx3bkjeih5r4hvzzfgx6azuin7q.sj1: The file or directory is corrupted and unreadable.; GetFileInformationByHandle d:\STORJ\blobs\pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa\3q/lejo53ggcmbudjzhctkd3jzxuj7ed63r5kagxwpqzdtqpkglna.sj1: The file or directory is corrupted and unreadable.; GetFileInformationByHandle d:\STORJ\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\av/4ko73nv426jw3uxqxcmjqp4okgntjbh6vtqmznznyxfdgzdm4q.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “group:\n— GetFileInformationByHandle d:\STORJ\blobs\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\fs/fkk2fkipbsfxr2l3yrmqqnbmx3bkjeih5r4hvzzfgx6azuin7q.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:714\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:652\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:612\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:258\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:468\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:633\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:54\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— GetFileInformationByHandle d:\STORJ\blobs\pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa\3q/lejo53ggcmbudjzhctkd3jzxuj7ed63r5kagxwpqzdtqpkglna.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:714\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:652\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:612\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:258\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:468\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:633\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:54\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n— GetFileInformationByHandle d:\STORJ\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\av/4ko73nv426jw3uxqxcmjqp4okgntjbh6vtqmznznyxfdgzdm4q.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:714\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:652\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:612\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:258\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:468\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:633\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:54\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
I have already solved it, you have to do a check of the unit to recover the data from the disk. It is back online.
