Hello, I know Iām going to have a power cut in the building. Is there something to do to anticipate this at the uptime level or too bad for me?
Thanks
Thanks
Nothing except for the standard advise to shut down things neatly prior to cutting the power. Then make it as short as possibly. But for now you can have 40% down time without being suspended, so you have plenty of time. While you are offline though, data will go through repair, which means you are slowly losing data. Try to keep it below 4 hours to prevent that from happening.
thank you for the answer
