Erasure Code technology
According to erasure coding technology, after a file is uploaded to the network, it will be divided into several segments with a size of 64MB, and then it will be divided into several strips of different sizes, and the size of the fragments finally divided into For how much, I want to know how erasure codes are implemented, thank you.
You not realy understand the proces, it will be devided to 64mb segmants and 80 pieses each segment in your pc encrypted and then uploaded to network
That was close.
First the data gets encrypted and then reed solomon encoding. That has the advantage that we can repair it without having to decrypt it.
