Never seen such errors before. What does it mean?
2024-04-22T18:48:37+02:00 ERROR blobscache satPiecesTotal < 0 {"satPiecesTotal": -3072}
2024-04-22T18:48:37+02:00 ERROR blobscache satPiecesContentSize < 0 {"satPiecesContentSize": -2560}
2024-04-22T18:48:37+02:00 ERROR blobscache satPiecesTotal < 0 {"satPiecesTotal": -1280}
2024-04-22T18:48:37+02:00 ERROR blobscache satPiecesContentSize < 0 {"satPiecesContentSize": -768}
Alexey
April 23, 2024, 8:02am
2
This is only mean that your used-space-filewalker didn’t finish its job or you disabled it. In the latter case I would suggest to enable it back, save the config and restart the node.
Yes , used-space-filewalker is running.
If this is expected behavior, why calling it error? Should be info message then.
Alexey
April 25, 2024, 8:25am
4
Yes, it’s expected, because normally it should not occur, if used-space-filewalker wasn’t disabled. But when the used-space-filewalker will finish its work and update databases, this error should gone.
Bivvo
August 27, 2024, 8:45pm
6
Same here with 200k ERROR entries per hour on one of my nodes.
2024-08-27T19:32:26Z ERROR blobscache satPiecesTotal < 0 {"Process": "storagenode", "satPiecesTotal": -250368}
2024-08-27T19:32:26Z ERROR blobscache satPiecesContentSize < 0 {"Process": "storagenode", "satPiecesContentSize": -249856}
2024-08-27T19:32:26Z ERROR blobscache satPiecesTotal < 0 {"Process": "storagenode", "satPiecesTotal": -3840}
2024-08-27T19:32:26Z ERROR blobscache satPiecesContentSize < 0 {"Process": "storagenode", "satPiecesContentSize": -3328}
2024-08-27T19:32:26Z ERROR blobscache satPiecesTotal < 0 {"Process": "storagenode", "satPiecesTotal": -197888}
2024-08-27T19:32:26Z ERROR blobscache satPiecesContentSize < 0 {"Process": "storagenode", "satPiecesContentSize": -197376}
2024-08-27T19:32:27Z ERROR blobscache satPiecesTotal < 0 {"Process": "storagenode", "satPiecesTotal": -197888}
2024-08-27T19:32:27Z ERROR blobscache satPiecesContentSize < 0 {"Process": "storagenode", "satPiecesContentSize": -197376}
Shouldn’t that be a warning instead of an error? It’s simply wasting resources, if no FATAL error occurs and the fw finishes sooner or later.
@Alexey
Alexey
August 28, 2024, 3:30am
7
The answer has not changed. While databases are not updated, you may see this error.
Enable scan on startup, if you disabled it (it’s enabled by default), save the config and restart the node.
Then monitor that the filewalker wouldn’t crash (search for error and used-space in your logs).
To track its progress:
Windows/PowerShell
Logs should be at least info level
Used space filewalker
Regulated by the parameter in the config.yaml file or as a command line argument (add -- before the parameter, remove :, place it after the image name in your docker run command):
# if set to true, all pieces disk usage is recalculated on startup (default true)
storage2.piece-scan-on-startup: true
to watch for a progress:
cat "C:\Program Files\Storj\Storage Node\*.log" -Wait | sls "used-space-filewalker" | sls "sta…
Bivvo
August 28, 2024, 3:16pm
8
both nodes have --pieces.enable-lazy-filewalker="true"
Alexey
August 29, 2024, 4:36am
9
Then please make sure, that it’s not failed during the way.
I have also had strange calculations for 2 months now. Is this normal?
[111]
[222]
