ERROR blobscache newTrashTotal < 0 {"newTrashTotal": -13263104}
I found it in the log, it appeared right after rebooting storagenode …
Hi @peem I dont have an immediate answer for you, but I do know one of the mods flagged it for the engineering team to look at. Thank you for your post
I have same issue. I found
ERROR blobscache trashTotal < 0 {“trashTotal”: -110801152}
node has been up more than a day without restart.
Note, this can happen when node restarts without having a chance to update the data in sqlite cache and when there are deletes happening.
It should eventually self-correct. If it keeps showing that line, then it could mean an underlying problem.
Thanks @Egon. I will keep checking
I just got this about 15 seconds before my nodes suspension score for a satellite dropped from 100 to 95. Its audit score is 100 and the uptime is 99.72.
Check for disk errors, disk full or ro?
The disk is not, but the node is. I assume a full node is capable of managing its own storage.
