hi, i have problem
2020-03-12T13:09:55.236Z INFO version running on version v0.34.6
2020-03-12T13:09:55.245Z INFO db.migration Database Version {“version”: 31}
Error: Error during preflight check for storagenode databases: storage node preflight database error: used_serial: expected schema does not match actual: &dbschema.Schema{
Tables: *dbschema.Table{
Columns: []*dbschema.Column{ -
&{Name: "id", Type: "int"}, -
&{Name: "name", Type: "varchar(30)", IsNullable: true}, -
PrimaryKey: []string{"id"}, -
}, &{Name: "used_serial_", Columns: []*dbschema.Column{&{Name: "expiration", Type: "TIMESTAMP"}, &{Name: "satellite_id", Type: "BLOB"}, &{Name: "serial_number", Type: "BLOB"}}}, }, Indexes: []*dbschema.Index{&{Name: "idx_used_serial_", Table: "used_serial_", Columns: []string{"expiration"}}, &{Name: "pk_used_serial_", Table: "used_serial_", Columns: []string{"satellite_id", "serial_number"}}},}
storj.io/storj/storagenode/storagenodedb.(*DB).Preflight:301 main.cmdRun:198 storj.io/storj/pkg/process.cleanup.func1.2:312 storj.io/storj/pkg/process.cleanup.func1:330 github.com/spf13/cobra.(*Command).execute:826 github.com/spf13/cobra.(*Command).ExecuteC:914 github.com/spf13/cobra.(*Command).Execute:864 storj.io/storj/pkg/process.ExecWithCustomConfig:84 storj.io/storj/pkg/process.ExecCustomDebug:66 main.main:328 runtime.main:203
