Hey Alexey, thank you for the article, I followed it through and think i\m in a better place than before but still getting errors. Here is what the logs is saying now… Does it mean I need to start fresh?
2021-09-29T07:32:02.223Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2021-09-29T07:32:02.229Z INFO Operator email {“Address”: “**************”}
2021-09-29T07:32:02.230Z INFO Operator wallet {“Address”: “*************”}
2021-09-29T07:32:09.032Z INFO Telemetry enabled {“instance ID”: “19KAa7Ss84z9jhq2hcX8LGKYc8MUQomNFmiCBQBG1FvmMa9zxS”}
2021-09-29T07:32:09.113Z INFO db.migration Database Version {“version”: 53}
2021-09-29T07:32:37.121Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2021-09-29T07:32:38.016Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2021-09-29T07:32:38.017Z INFO bandwidth Performing bandwidth usage rollups
2021-09-29T07:32:38.017Z WARN piecestore:monitor Disk space is less than requested. Allocated space is {“bytes”: 193092812800}
2021-09-29T07:32:38.017Z ERROR piecestore:monitor Total disk space is less than required minimum {“bytes”: 500000000000}
2021-09-29T07:32:38.017Z INFO Node 19KAa7Ss84z9jhq2hcX8LGKYc8MUQomNFmiCBQBG1FvmMa9zxS started
2021-09-29T07:32:38.017Z INFO Public server started on [::]:28967
2021-09-29T07:32:38.017Z INFO Private server started on 127.0.0.1:7778
2021-09-29T07:32:38.017Z ERROR services unexpected shutdown of a runner {“name”: “piecestore:monitor”, “error”: “piecestore monitor: disk space requirement not met”, “errorVerbose”: “piecestore monitor: disk space requirement not met\n\tstorj.io/storj/storagenode/monitor.(*Service).Run:123\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-09-29T07:32:38.018Z ERROR nodestats:cache Get pricing-model/join date failed {“error”: “context canceled”}
2021-09-29T07:32:38.019Z INFO trust Scheduling next refresh {“after”: “5h21m47.431829094s”}
2021-09-29T07:32:38.019Z ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:154\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:367\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-09-29T07:32:38.020Z ERROR gracefulexit:chore error retrieving satellites. {“error”: “satellitesdb: context canceled”, “errorVerbose”: “satellitesdb: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:149\n\tstorj.io/storj/storagenode/gracefulexit.(*service).ListPendingExits:89\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run.func1:53\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run:50\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-09-29T07:32:38.020Z ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:154\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:367\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-09-29T07:32:38.020Z ERROR gracefulexit:blobscleaner couldn’t receive satellite’s GE status {“error”: “context canceled”}
2021-09-29T07:32:38.021Z ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:154\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:367\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-09-29T07:32:38.021Z ERROR collector error during collecting pieces: {“error”: “pieceexpirationdb: context canceled”, “errorVerbose”: “pieceexpirationdb: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:39\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:521\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:88\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-09-29T07:32:38.021Z ERROR piecestore:cache error getting current used space: {“error”: “context canceled; context canceled; context canceled; context canceled; context canceled; context canceled”, “errorVerbose”: “group:\n— context canceled\n— context canceled\n— context canceled\n— context canceled\n— context canceled\n— context canceled”}
2021-09-29T07:32:38.456Z ERROR bandwidth Could not rollup bandwidth usage {“error”: “sql: transaction has already been committed or rolled back”}
2021-09-29T07:32:55.520Z INFO Got a signal from the OS: “terminated”
Error: piecestore monitor: disk space requirement not met
If the worse has happened and I need to start again, is it truly from the beginning or can I pick off somewhat where I left off?
Thanks in advance
