Hi. I meet a problem on my new node. It worked perfectly about 48h before crashing. Now, my SN can’t help restarting.
Thank you in advance for your help.
Here are my logs:
$sudo docker logs --tail 40 storagenode
Error: Error starting master database on storagenode: database: disk I/O error: input/output error
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:323
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:305
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:281
storj.io/storj/storagenode/storagenodedb.OpenExisting:248
main.cmdRun:160
storj.io/private/process.cleanup.func1.4:363
storj.io/private/process.cleanup.func1:381
github.com/spf13/cobra.(*Command).execute:842
github.com/spf13/cobra.(*Command).ExecuteC:950
github.com/spf13/cobra.(*Command).Execute:887
storj.io/private/process.ExecWithCustomConfig:88
storj.io/private/process.ExecCustomDebug:70
main.main:385
runtime.main:204
2021-02-19T23:34:46.561Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2021-02-19T23:34:46.574Z INFO Operator email {"Address": "xxxx"}
2021-02-19T23:34:46.575Z INFO Operator wallet {"Address": "xxxx"}
Looks like your disk failed? Are you able to browse the disk at all?
Hello, you’re right. My disk became unmounted and crashed my system.
I umounted it and i am verifying bad blocks. I’ll keep informed.
Thank you both of you for your help.
bad news, the test is still pending and I have lots of bad blocks… I think I’ll have to replace it…
I changed my disk and restarted the node. Everything seems to be ok now.
Thank you for your help.
