Bivvo
August 16, 2023, 7:45pm
1
Does not seem to be an operational issue, really. What do you think? Nodes are running normal with this coming up from time to time.
2023-08-16T15:58:48Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed
\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:83
\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105
\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707
\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57
\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87
\truntime/pprof.Do:44
\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86
\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
Seems to happen, when a new version is installed. Currently on that node: v1.85.1
Alexey
August 17, 2023, 8:26am
2
What’s OS? What’s HDD? Is it SMR?
Bivvo
August 17, 2023, 8:53am
3
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3
17:24:16 BST 2023 aarch64 GNU/Linux
… and CMR
Alexey
August 18, 2023, 3:08am
4
How much free memory? Preferably when this issue is happen.
I suspect either overheated USB controller or OOM.
So may be it’s a good idea to search for OOM in your journals, i.e.
journalctl | grep -i oom | tail
It’s also advisable to check disk for errors.
Bivvo
August 18, 2023, 4:58am
5
Thx. I’ve reduced sd card usage with the following tips .
Does not provide a result.
Last time I’ve checked the disks, 100% was fine.
Typically my Raspi is out of CPU, with more or less IOWAIT, but RAM is fine:
It’s not looking that way always, but as you can see, CPU usage seems to be a limiting factor with 2 nodes serving.
I’ve limited RAM usage for both nodes:
--memory=1200m \
im seeing this in logs for 1.85.1
Alexey
August 20, 2023, 2:43am
7
is it context canceled or killed?
Bivvo
August 20, 2023, 4:34am
8
Bivvo:
signal: killed
In my case. But I think you’ve asked @ItsHass
Alexey
August 20, 2023, 7:34am
9
You are correct. I asked @ItsHass
I found killed error in logs of one of my nodes (Windows, Docker Desktop). It has enough free RAM (24GiB), so I do not believe it’s related to RAM.
But I did chkdsk on that time (read-only), so maybe related.
