@Dylan is 0.21.3 still the latest version?
Nevermind same error on version 0.22.2âŚ
When try
FATAL Unrecoverable error {âerrorâ: âerror occurred while signing certificate: rpc error: code = Internal desc = certificates peer error: error claiming authorization\n(identity files were still generated and saved, if you try again existing files will be loaded)â, âerrorVerboseâ: âerror occurred while signing certificate: rpc error: code = Internal desc = certificates peer error: error claiming authorization\n(identity files were still generated and saved, if you try again existing files will be loaded)\n\tmain.cmdAuthorize:212\n\tstorj.io/storj/pkg/process.cleanup.func1.2:275\n\tstorj.io/storj/pkg/process.cleanup.func1:293\n\tgithub.com/spf13/cobra.(*Command).execute:762\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:852\n\tgithub.com/spf13/cobra.(*Command).Execute:800\n\tstorj.io/storj/pkg/process.Exec:74\n\tmain.main:83\n\truntime.main:203â}
Hello @Vadim,
Seems your token already claimed. Please, check your identity folder, perhaps itâs already signed.
For Linux
ls -l ~/.local/share/storj/identity/storagenode
For Windows PowerShell:
ls $env:AppData/Storj/Identity/storagenode
Hello.
I am not used it before. there is only 4 files, ca sert and key and indentitysert and key
Please, try to synchronize your system clock with an internet.
Thank you.
It Worked. I instaled NetTime to pc also.
@Alexey I just want to learn some more here.
What made you understand that vadims computer time was out of sync?
@John.A One of the Devâs mentioned that some of the errors on the satellite side were âclaim timestamp is outside of max delay windowâ, so as one troubleshooting option we think it could be is that the userâs computerâs clock is wrong
