Error on start for node
getting this error… need some help…
2024-07-25T22:05:32+08:00 DEBUG Version info {“Version”: “1.105.4”, “Commit Hash”: “e20f78fa5d0e07eecfb615aa8b74075c7ae25b92”, “Build Timestamp”: “2024-05-29 20:48:22 +0800 +08”, “Release Build”: true}
2024-07-25T22:05:33+08:00 DEBUG version Allowed minimum version from control server. {“Minimum Version”: “1.105.4”}
2024-07-25T22:05:33+08:00 DEBUG version Running on allowed version. {“Version”: “1.105.4”}
2024-07-25T22:05:33+08:00 INFO Telemetry enabled {“instance ID”: “1nCn18as73juoKNQZFpuuut6xG1nrZB7VyTuqF9NxWX5cbL8Lt”}
2024-07-25T22:05:33+08:00 INFO Event collection enabled {“instance ID”: “1nCn18as73juoKNQZFpuuut6xG1nrZB7VyTuqF9NxWX5cbL8Lt”}
2024-07-25T22:05:33+08:00 INFO db.migration Database Version {“version”: 57}
2024-07-25T22:05:33+08:00 DEBUG db Database version is up to date {“version”: 57}
2024-07-25T22:05:33+08:00 DEBUG trust Fetched URLs from source; updating cache {“source”: “https://www.storj.io/dcs-satellites”, “count”: 4}
2024-07-25T22:05:33+08:00 DEBUG trust Satellite is trusted {“id”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”}
2024-07-25T22:05:33+08:00 DEBUG trust Satellite is trusted {“id”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:33+08:00 DEBUG trust Satellite is trusted {“id”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2024-07-25T22:05:33+08:00 DEBUG trust Satellite is trusted {“id”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:33+08:00 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2024-07-25T22:05:34+08:00 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2024-07-25T22:05:34+08:00 DEBUG servers started {“items”: [“debug”, “server”]}
2024-07-25T22:05:34+08:00 INFO Node 1nCn18as73juoKNQZFpuuut6xG1nrZB7VyTuqF9NxWX5cbL8Lt started
2024-07-25T22:05:34+08:00 INFO Public server started on [::]:28969
2024-07-25T22:05:34+08:00 INFO trust Scheduling next refresh {“after”: “5h48m50.202794137s”}
2024-07-25T22:05:34+08:00 INFO Private server started on 127.0.0.1:7778
2024-07-25T22:05:34+08:00 INFO bandwidth Persisting bandwidth usage cache to db
2024-07-25T22:05:34+08:00 DEBUG pieces:trash starting to empty trash
2024-07-25T22:05:34+08:00 INFO pieces:trash emptying trash started {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 INFO retain Prepared to run a Retain request. {“cachePath”: “C:\Storj\Storage Node/retain”, “Created Before”: “2024-07-18T01:59:59+08:00”, “Filter Size”: 10053592, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {“satelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {“satelliteID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”}
2024-07-25T22:05:34+08:00 DEBUG services started {“items”: [“version:chore”, “trust”, “contact:chore”, “bandwidth”, “PieceDeleter”, “pieces:trash”, “piecestore:cache”, “piecestore:monitor”, “retain”, “ordersfilestore”, “orders”, “nodestats:cache”, “console:endpoint”, “gracefulexit:blobscleaner”, “gracefulexit:chore”, “forgetsatellite:chore”, “collector”]}
2024-07-25T22:05:34+08:00 WARN piecestore:monitor Disk space is less than requested. Allocated space is {“bytes”: 7120457728}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker subprocess started {“satelliteID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {“satelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 DEBUG contact:chore Starting cycle {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:34+08:00 DEBUG contact:chore Starting cycle {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2024-07-25T22:05:34+08:00 DEBUG contact:chore Starting cycle {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”}
2024-07-25T22:05:34+08:00 DEBUG contact:chore Starting cycle {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 ERROR services unexpected shutdown of a runner {“name”: “piecestore:monitor”, “error”: “piecestore monitor: error verifying location and/or readability of storage directory: open D:\Storage\storage-dir-verification: The system cannot find the file specified.”, “errorVerbose”: “piecestore monitor: error verifying location and/or readability of storage directory: open D:\Storage\storage-dir-verification: The system cannot find the file specified.\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:157\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:140\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
2024-07-25T22:05:34+08:00 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2024-07-25T22:05:34+08:00 INFO contact:service context cancelled {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.gc-filewalker starting subprocess {“satelliteID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:34+08:00 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2024-07-25T22:05:34+08:00 INFO contact:service context cancelled {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 ERROR version failed to get process version info {“error”: “version checker client: Get "https://version.storj.io": context canceled”, “errorVerbose”: “version checker client: Get "https://version.storj.io": context canceled\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tstorj.io/storj/private/version/checker.(*Client).Process:89\n\tstorj.io/storj/private/version/checker.(*Service).checkVersion:104\n\tstorj.io/storj/private/version/checker.(*Service).CheckVersion:78\n\tstorj.io/storj/storagenode/version.(*Chore).checkVersion:115\n\tstorj.io/storj/storagenode/version.(*Chore).RunOnce:71\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/version.(*Chore).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
2024-07-25T22:05:34+08:00 ERROR contact:service ping satellite failed {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2024-07-25T22:05:34+08:00 INFO contact:service context cancelled {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”}
2024-07-25T22:05:34+08:00 ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: operation was canceled”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.126.92.94:7777: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2024-07-25T22:05:34+08:00 INFO contact:service context cancelled {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2024-07-25T22:05:34+08:00 ERROR nodestats:cache Get pricing-model/join date failed {“error”: “context canceled”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker subprocess exited with status {“satelliteID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “status”: 1, “error”: “exit status 1”}
2024-07-25T22:05:34+08:00 ERROR pieces failed to lazywalk space used by satellite {“error”: “lazyfilewalker: exit status 1”, “errorVerbose”: “lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess exited with status {“satelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “status”: 1, “error”: “exit status 1”}
2024-07-25T22:05:34+08:00 ERROR pieces:trash emptying trash failed {“error”: “pieces error: lazyfilewalker: exit status 1”, “errorVerbose”: “pieces error: lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:187\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:422\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89”}
2024-07-25T22:05:34+08:00 DEBUG db number of subdirs {“count”: 1024}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {“satelliteID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”}
2024-07-25T22:05:34+08:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {“satelliteID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “error”: “context canceled”}
2024-07-25T22:05:34+08:00 ERROR pieces failed to lazywalk space used by satellite {“error”: “lazyfilewalker: context canceled”, “errorVerbose”: “lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”, “Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {“satelliteID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:34+08:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {“satelliteID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “error”: “context canceled”}
2024-07-25T22:05:34+08:00 ERROR pieces failed to lazywalk space used by satellite {“error”: “lazyfilewalker: context canceled”, “errorVerbose”: “lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {“satelliteID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2024-07-25T22:05:34+08:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {“satelliteID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “error”: “context canceled”}
2024-07-25T22:05:34+08:00 ERROR pieces failed to lazywalk space used by satellite {“error”: “lazyfilewalker: context canceled”, “errorVerbose”: “lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {“satelliteID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”}
2024-07-25T22:05:34+08:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {“satelliteID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “error”: “context canceled”}
2024-07-25T22:05:34+08:00 ERROR pieces failed to lazywalk space used by satellite {“error”: “lazyfilewalker: context canceled”, “errorVerbose”: “lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”}
2024-07-25T22:05:34+08:00 INFO lazyfilewalker.used-space-filewalker starting subprocess {“satelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {“satelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “error”: “context canceled”}
2024-07-25T22:05:34+08:00 ERROR pieces failed to lazywalk space used by satellite {“error”: “lazyfilewalker: context canceled”, “errorVerbose”: “lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:707\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2024-07-25T22:05:34+08:00 ERROR piecestore:cache error getting current used space: {“error”: “filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled”, “errorVerbose”: “group:\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:716\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:716\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:716\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:716\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:716\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:716\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:58\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
2024-07-25T22:05:34+08:00 ERROR lazyfilewalker.gc-filewalker failed to start subprocess {“satelliteID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “error”: “context canceled”}
2024-07-25T22:05:34+08:00 ERROR pieces lazyfilewalker failed {“error”: “lazyfilewalker: context canceled”, “errorVerbose”: “lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:561\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:373\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:259\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
2024-07-25T22:05:34+08:00 ERROR filewalker failed to get progress from database
2024-07-25T22:05:34+08:00 ERROR retain retain pieces failed {“cachePath”: “C:\Storj\Storage Node/retain”, “error”: “retain: filewalker: context canceled”, “errorVerbose”: “retain: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePiecesToTrash:181\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:568\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:373\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:259\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
2024-07-25T22:05:35+08:00 ERROR failure during run {“error”: “piecestore monitor: error verifying location and/or readability of storage directory: open D:\Storage\storage-dir-verification: The system cannot find the file specified.”, “errorVerbose”: “piecestore monitor: error verifying location and/or readability of storage directory: open D:\Storage\storage-dir-verification: The system cannot find the file specified.\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:157\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:140\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
2024-07-25T22:05:35+08:00 FATAL Unrecoverable error {“error”: “piecestore monitor: error verifying location and/or readability of storage directory: open D:\Storage\storage-dir-verification: The system cannot find the file specified.”, “errorVerbose”: “piecestore monitor: error verifying location and/or readability of storage directory: open D:\Storage\storage-dir-verification: The system cannot find the file specified.\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:157\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:140\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
my storage left about 5-6 gb free space… anything i can do ?
i tried running checking for files older stand 8 days… there are some space there… still dont delete it ?
Seems the node crashed (see FATAL-error) due to it unable to read/see your " D:\Storage" folder. Specifically the “storage-dir-verification”-file which should be located in “D:\Storage”
Can you confirm the folder is there and this particular file is also present?
is that the database file it meant?
No, its a file called “storage-dir-verification”. It is in the same folder as all the .db files. In your case that would be “D:\Storage”. Please check.
gosh…that file is missing… what should i do next
