ERROR piecestore
2021-04-26T09: 25: 01,739 + 0200 ERROR piecestore: Error de caché conseguir espacio utilizado actual: { “error”: “CreateFile E: \ almacenamiento \ manchas \ qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa \ FH / vzpd4p5rsdz7xwr25umxarmqdl7zwx2u7w6fyyqapp3wv5vs3a.sj1: El archivo o Directorio está DAA ± ado o es ilegible .; CreateFile E: \ storage \ blobs \ ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa \ x6 / hnuse76w2uz5eu42gfs7x5zfa4ht4xeknmwboif47tqsv1bá5pa. CreateFile E: \ storage \ blobs \ v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa \ pn / jeacrqigxoakenfubaatizl4ba33bw45erzpbixm6cjau7evja.tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:787\n\tstorj.io/storj/storage/filestore.(*Dir .walkNamespaceInPath: 725 \ n \ tstorj.io/storj/storage/filestore.(*Directorio .WalkNamespace: 685 \ n \ tstorj.io/storj/storage/filestore.(*blobStore .WalkNamespace: 280 \ n \ tstorj.io/storj/storagenode/pieces.(*Store .Walk SatellitePieces: 496 \ n \ tstorj.io/storj/storagenode/pieces.(*Store .SpaceUsedTotalAndBy Satellite: 661 \ n \ tstorj.io/storj/storagenode/pieces.(*CacheService .Ejecutar: 54 \ n \ tstorj.io/storj/private/ ciclo de vida. (* Grupo .Run.func2.1: 81 \ n \ truntime / pprof.Do: 40 \ n \ tstorj.io/storj/private/lifecycle.(*Grupo .Run.func2: 80 \ n [tgolang.org/x/sync/errgroup.(*Group](http://tgolang.org/x/sync/errgroup.(*Group) ) .Go.func1: 57 \ n— CreateFile E: \ storage \ blobs \ ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaaa \ x6xvw5qaaaaaa \ x6x5eq. ilegible. \ n \
it turns off every 4 hours please help I do not want to waste 7 months and above without receiving a payment is urgent !!!
See my response in your other thread:
The problem is likely to be the same one.
How can it be fixed or nothing can be done anymore
As long as your disk did not lose data (or just a few files at most) and your node has OK audit scores, most problems can be fixed.
But it takes time to investigate and research this forum: most problems have been encountered already.
I see you decided to stop your node on your other thread though.
If your node hasn’t been destroyed, is still in relatively “good shape” and if you change your mind, maybe the community can help you get it back on its feet. Up to you :slight_smile:
