I have installed a fresh QNAP with newest firmware an was only as admin logged in and have the problem too after all delete and new install the storj app 1.09 (same like 1.08)
I have promt on ssh:
chmod -R 777 /share/CACHEDEV1_DATA/Container/container-station-data/lib/docker/containers
same promlem after that:
Error: Error starting master database on storagenode: storage node database error: unable to open database file: operation not permitted
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:272
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:187
storj.io/storj/storagenode/storagenodedb.New:174
main.cmdRun:150
storj.io/private/process.cleanup.func1.4:353
storj.io/private/process.cleanup.func1:371
github.com/spf13/cobra.(*Command).execute:840
github.com/spf13/cobra.(*Command).ExecuteC:945
github.com/spf13/cobra.(*Command).Execute:885
storj.io/private/process.ExecWithCustomConfig:88
storj.io/private/process.ExecCustomDebug:70
main.main:323
runtime.main:203
Hi Karl,
It was always admin logged in - I enabled 2 factor - not sure if that would have created another ‘admin’.
Best, Michaël
Karl,
Made all container folder read write x enabled for user (admin) and group.
Same error - (like Otti24)
Best, Michaël
Please don’t do this… ever.
Agree.
It’s always a bad idea to 777 almost anything. And anytime I’ve seen someone recommend it, it usually doesn’t work out that well or doesn’t fix the problem.
This problem seems to be QNAP specific. I’ve been reading in various other forums because it seems quite curious…
My discoveries:
- QNAP docker requires the
-voption for volume mounting and does not support the-mountoption. - QNAP docker does not necessarily run as
GUID/UID 0and might need to specially configured to do so. - QTS has an installation of DSL as a base … and is not easy to sort through… I went looking for OS image files and there aren’t any. The download from QNAP is additional software and configuration, not the whole OS.
So, I downloaded DSL:
http://www.damnsmalllinux.org/
And started looking around, but it seems that the issue is probably related to docker configuration rather actual file permissions.
Additional…
Maybe one of the recent security QNAP patches for something on the vulnerability list changed the default docker settings:
The curious thing is that it’s only affecting particular configurations of QNAPs - there has to be something in-common.
QNAP Docker should also support -mount
[karl@**** ~]$ docker run --help | grep mount
--mount mount Attach a filesystem mount to the container
-v, --volume list Bind mount a volume
I found this reddit thread:
https://www.reddit.com/r/qnap/comments/hovaua/volume_mounting_in_container_station_permission/
In a few other places, I noticed that people indicated that QNAP only supports volumes and does not support bind mounts.
In the source code of the QNAP app, the docker run command uses the -v option.
I remember reading around here that -mount is recommended and issues occur with -v … however, after reading about QNAP not supporting -mount I figured that the only method to running a node was -v …
In any case, I don’t have a QNAP device myself… So, it’s unlikely that I’ll be able to find the problem.
great bit of digging @anon27637763. We’re going through a few variations of the container config and will post our findings next week.
There has also been talk about replacing the container with just the binary in future versions.
