I’m getting this error while running the gateway in mac osx catalina:
miguel@MacBook-Pro-de-Miguel S3 % ./gateway_darwin_amd64 run
2020-02-08T14:08:19.662+0100 INFO Configuration loaded from: /Users/miguel/Library/Application Support/Storj/Gateway/config.yaml
2020-02-08T14:08:20.593+0100 INFO running on version v0.31.12
2020-02-08T14:08:20.594+0100 INFO Starting Storj S3-compatible gateway!
2020-02-08T14:08:20.594+0100 INFO Endpoint: 127.0.0.1:7777
2020-02-08T14:08:20.594+0100 INFO Access key: W2vgTLQGZfBn1azhK3********
2020-02-08T14:08:20.594+0100 INFO Secret key: 2vDCLKzpCzab5P3Wm1********
Created minio configuration file successfully at /Users/miguel/Library/Application Support/Storj/Gateway/minio
This is happened with me also when ever I want to run gateway in my mac it shows me error 0xe8000015 which I don’t know how to fix. If anyone can know the fixes ten suggest me.
Update: I also have this issue, as well as some other users. I can confirm that although this error shows up, the gateway does in-fact still run as normal, and you can simply ignore this error.
Hey! We’re still investigating of course, but it hasn’t been a high priority because this appears to be a benign error? I am reproducing the same error on my Mac, but the Gateway still works as expected. I’ll report back if I discover how to get the error to go away.
Does the gateway not continue working for you, even with the error? Perhaps I’m not experiencing the same thing.
I’m very confused about these two lines. First off, 127.0.0.1.7777? Don’t you mean 127.0.0.1:7777?
Secondly, why is curl changing the URL? This is puzzling. My guess is there is some small typo in your configuration (maybe the . vs : one)
Pretty sure the gateway doesn’t run over https. Also, s3fs seems to assume vhost paths, which is why the translation of that url happens. I’m not familiar with using s3fs myself, but you should look for an option to turn off vhost paths or enable direct path style.
it looks like you’re running into the rate limit. You can contact support at support.tardigrade.io to ask to have it increased. Submit a request button at the top.
Don’t hesitate to ask for this, I see many people running into this and they need the feedback to determine what a realistic and usable rate limit is.
