Noticed my Docker container rebooted on the last two storagenode-update. The log messages are a little confusing. Wondering if this is expected:
2023-08-16T08:41:06.689Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.60.3"}
2022-08-16T08:41:06.689Z INFO Download started. {"Process": "storagenode-updater", "From": "https://github.com/storj/storj/releases/download/v1.61.1/storagenode-updater_linux_amd64.zip", "To": "/tmp/storagenode-updater_linux_amd64.1623943428.zip"}
2022-08-16 08:41:07,525 INFO exited: storagenode (exit status 0; expected)
2022-08-16T08:41:07.770Z INFO Download finished. {"Process": "storagenode-updater", "From": "https://github.com/storj/storj/releases/download/v1.61.1/storagenode-updater_linux_amd64.zip", "To": "/tmp/storagenode-updater_linux_amd64.1623943428.zip"}
2022-08-16 08:41:07,773 INFO spawned: 'storagenode' with pid 16696
2022-08-16T08:41:07.801Z INFO Restarting service. {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2022-08-16 08:41:07,804 INFO exited: storagenode-updater (exit status 1; not expected)
2022-08-16T08:41:07.888Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2022-08-16 08:41:07,890 INFO spawned: 'storagenode-updater' with pid 16713
2022-08-16T08:41:07.907Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "contact.external-address"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet-features"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "console.address"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.email"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.development"}
2022-08-16T08:41:07.907Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.output"}
2022-08-16T08:41:07.956Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2022-08-16T08:41:07.956Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2022-08-16T08:41:07.970Z INFO Operator email {"Process": "storagenode", "Address": "mike@mpsharp.com"}
2022-08-16T08:41:07.970Z INFO Operator wallet {"Process": "storagenode", "Address": "0x14Ad0d492b01cf3E8822dB3e179BE8196Ec59C8c"}
2022-08-16T08:41:08.078Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.61.1"}
2022-08-16T08:41:08.078Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2022-08-16 08:41:08,109 WARN received SIGQUIT indicating exit request
2022-08-16 08:41:08,110 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2022-08-16T08:41:08.110Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2022-08-16T08:41:08.110Z ERROR Error retrieving version info. {"Process": "storagenode-updater", "error": "version checker client: Get \"https://version.storj.io\": context canceled", "errorVerbose": "version checker client: Get \"https://version.storj.io\": context canceled\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tmain.loopFunc:21\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tmain.cmdRun:136\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:20\n\truntime.main:255"}
2022-08-16 08:41:08,111 INFO stopped: storagenode-updater (exit status 0)
2022-08-16T08:41:08.111Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode"}
Error: Error starting master database on storagenode: database: used_serial opening file "config/storage/used_serial.db" failed: context canceled
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:324
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:306
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:281
storj.io/storj/storagenode/storagenodedb.OpenExisting:248
main.cmdRun:193
main.main:479
runtime.main:255
2022-08-16 08:41:08,145 INFO stopped: storagenode (exit status 1)
2022-08-16 08:41:08,146 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2022-08-16 08:41:18,201 INFO Set uid to user 0 succeeded
2022-08-16 08:41:18,252 INFO RPC interface 'supervisor' initialized
2022-08-16 08:41:18,252 INFO supervisord started with pid 1
2022-08-16 08:41:19,254 INFO spawned: 'processes-exit-eventlistener' with pid 11
2022-08-16 08:41:19,256 INFO spawned: 'storagenode' with pid 12
2022-08-16 08:41:19,258 INFO spawned: 'storagenode-updater' with pid 13
2022-08-16T08:41:19.280Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "console.address"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet-features"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "contact.external-address"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.email"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.level"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.output"}
2022-08-16T08:41:19.280Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.caller"}
2022-08-16T08:41:19.281Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2022-08-16T08:41:19.294Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.61.1"}
2022-08-16T08:41:19.294Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2022-08-16T08:41:19.324Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2022-08-16T08:41:19.324Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2022-08-16T08:41:19.337Z INFO Operator email {"Process": "storagenode", "Address": "mike@mpsharp.com"}
2022-08-16T08:41:19.337Z INFO Operator wallet {"Process": "storagenode", "Address": "0x14Ad0d492b01cf3E8822dB3e179BE8196Ec59C8c"}
2022-08-16T08:41:20.295Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.61.1"}
2022-08-16T08:41:20.295Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2022-08-16 08:41:20,296 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-08-16 08:41:20,296 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-08-16 08:41:20,296 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-08-16T08:41:20.320Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.61.1"}
2022-08-16T08:41:20.320Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2022-08-16T08:41:20.331Z INFO Telemetry enabled {"Process": "storagenode", "instance ID": "1R7FVb1HWw6yaF9FcStumt1QYFjQVqQDW3SwV6rMcrsWmiFWbd"}
2022-08-16T08:41:20.387Z INFO db.migration Database Version {"Process": "storagenode", "version": 53}
2022-08-16T08:41:21.439Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"Process": "storagenode"}
2022-08-16T08:41:22.029Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"Process": "storagenode"}
2022-08-16T08:41:22.030Z INFO Node 1R7FVb1HWw6yaF9FcStumt1QYFjQVqQDW3SwV6rMcrsWmiFWbd started {"Process": "storagenode"}
2022-08-16T08:41:22.030Z INFO Public server started on [::]:28967 {"Process": "storagenode"}
