Hello,
All of sudden I’ve been having problems with the storagenode image, and turned out that my bandwidth and used_serial databases were totally corrupt. I did try indeed to run integrity checks on them with a ‘database is not a file’ error as a result, and tried the dump on a sql file method, creating empty databases.
At this point I just decided to throw those databases away and let storagenode recreate them (althought I know it should not be done unless necessary, but here I thought it was my only solution) .
As a result, both databases now give me the famous schema unmatching problem in the logs :
020-03-28T16:34:10.422Z INFO Configuration loaded from: /app/config/config.yaml
2020-03-28T16:34:10.431Z INFO Operator email: cabrasm@outlook.com
2020-03-28T16:34:10.431Z INFO operator wallet: 0xefd4c1e7730f7b00e1Ac8438BbBDC2a1cD1cE93E
2020-03-28T16:34:10.959Z INFO version running on version v0.34.6
2020-03-28T16:34:10.970Z INFO db.migration Database Version {"version": 31}
Error: Error during preflight check for storagenode databases: storage node preflight database error: used_serial: expected schema does not match actual: &dbschema.Schema{
- Tables: []*dbschema.Table{
- Name: "used_serial_",
- Columns: []*dbschema.Column{
- &{Name: "expiration", Type: "TIMESTAMP"},
- &{Name: "satellite_id", Type: "BLOB"},
- &{Name: "serial_number", Type: "BLOB"},
+ Tables: nil,
- Indexes: []*dbschema.Index{
- &{Name: "idx_used_serial_", Table: "used_serial_", Columns: []string{"expiration"}},
- Name: "pk_used_serial_",
- Table: "used_serial_",
- Columns: []string{"satellite_id", "serial_number"},
+ Indexes: nil,
storj.io/storj/storagenode/storagenodedb.(*DB).Preflight:301
main.cmdRun:198
storj.io/storj/pkg/process.cleanup.func1.2:312
storj.io/storj/pkg/process.cleanup.func1:330
github.com/spf13/cobra.(*Command).execute:826
github.com/spf13/cobra.(*Command).ExecuteC:914
github.com/spf13/cobra.(*Command).Execute:864
storj.io/storj/pkg/process.ExecWithCustomConfig:84
storj.io/storj/pkg/process.ExecCustomDebug:66
main.main:328
runtime.main:203
2020-03-28T16:34:13.556Z INFO Configuration loaded from: /app/config/config.yaml
2020-03-28T16:34:13.565Z INFO Operator email: cabrasm@outlook.com
2020-03-28T16:34:13.565Z INFO operator wallet: 0xefd4c1e7730f7b00e1Ac8438BbBDC2a1cD1cE93E
2020-03-28T16:34:14.085Z INFO version running on version v0.34.6
2020-03-28T16:34:14.095Z INFO db.migration Database Version {"version": 31}
Error: Error during preflight check for storagenode databases: storage node preflight database error: bandwidth: expected schema does not match actual: &dbschema.Schema{
- Name: "bandwidth_usage",
- &{Name: "action", Type: "INTEGER"},
- &{Name: "amount", Type: "BIGINT"},
- &{Name: "created_at", Type: "TIMESTAMP"},
- Name: "bandwidth_usage_rollups",
- &{Name: "interval_start", Type: "TIMESTAMP"},
- PrimaryKey: []string{"action", "interval_start", "satellite_id"},
+ Tables: nil,
- Name: "idx_bandwidth_usage_created",
- Table: "bandwidth_usage",
- Columns: []string{"created_at"},
- Name: "idx_bandwidth_usage_satellite",
- Columns: []string{"satellite_id"},
+ Indexes: nil,
main.cmdRun:198
main.main:328
runtime.main:203
And I’ve been looking for sql queries to recreate them manually without success.
Any help would be appreciated, I see the community support is amazing around here and I just thank you all in advance for the help!
Manuel
