Explicit data expiration questions
I’m looking at https://docs.storj.io/api-reference/uplink-cli/cp-command and I see the following:
--expires string
optional expiration date of an object. Please use format ( yyyy-mm-ddThh:mm:ssZhh:mm )
Is there an equivalent switch for the put command?
Can the ls command also print the expiration date?
@Toyoo - Excellent questions. I believe the answers are “no” and “no”, but there isn’t any good reason for either of those. Possibly just no one has needed them yet.
I’ll take a look and see what can be done.
Result: I’ve added those features to uplink put and uplink ls in https://review.dev.storj.io/c/storj/storj/+/4798 and https://review.dev.storj.io/c/storj/storj/+/4799 respectively. If they survive review, they’ll be added to the release.
You can use the patches from those changesets if you want to test it out locally.
Gosh, I wish my workplace used Gerrit, I’m missing it so much. Thank you!
