Explicitly opt out of L1
Just a short, tiny question. Is it possible to explicitly opt out of the L1 payments by using the --operator.wallet-features switch? Imaginary use case: pausing payments.
I don’t think so.
Should I move this topic to the voting category?
What would happen if you just empty your wallet address? Does Storj Labs hold on to your payout until valid payout info is provided or would that just send your payout to /dev/null every month?
I think the node will not start.
If you believe it’s worth it…
This. It won’t start.
