2020-07-07T19:28:24.676-0300 ERROR piecestore failed to add order {"error": "ordersdb error: database is locked", "errorVerbose": "ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:52\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:665\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func5:312\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:328\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:996\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
2020-07-07T19:28:26.255-0300 ERROR piecestore failed to add order {"error": "ordersdb error: database is locked", "errorVerbose": "ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:52\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:665\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:409\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:996\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
2020-07-07T19:28:27.465-0300 ERROR piecestore failed to add order {"error": "ordersdb error: database is locked", "errorVerbose": "ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:52\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:665\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:409\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:996\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
2020-07-07T19:28:28.823-0300 ERROR piecestore failed to add order {"error": "ordersdb error: database is locked", "errorVerbose": "ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:52\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:665\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:409\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:996\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
2020-07-07T19:28:31.277-0300 ERROR piecestore failed to add order {"error": "ordersdb error: database is locked", "errorVerbose": "ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:52\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:665\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:409\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:996\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
What kind of errors are these? should I be worried? What things should I look to correct these errors and that will not happen again?
