Failed to create storage node peer: hashstore: unable to flock: hashstore: resource temporarily unavailable
Hello.
Could someone pass some ideas on how to i deal with this error?
Node does not start. No other errors visible. Tried to restart all machine, did not helped.
Thank you
2025-01-31T19:22:34Z INFO server kernel support for server-side tcp fast open remains disabled. {“Process”: “storagenode”}
2025-01-31T19:22:34Z INFO server enable with: sysctl -w net.ipv4.tcp_fastopen=3 {“Process”: “storagenode”}
2025-01-31T19:22:34Z ERROR failure during run {“Process”: “storagenode”, “error”: “Failed to create storage node peer: hashstore: unable to flock: hashstore: resource temporarily unavailable\n\tstorj.io/storj/storagenode/hashstore.NewStore:105\n\tstorj.io/storj/storagenode/hashstore.New:85\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).getDB:271\n\tstorj.io/storj/storagenode/piecestore.NewHashStoreBackend:105\n\tstorj.io/storj/storagenode.New:618\n\tmain.cmdRun:84\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272”, “errorVerbose”: “Failed to create storage node peer: hashstore: unable to flock: hashstore: resource temporarily unavailable\n\tstorj.io/storj/storagenode/hashstore.NewStore:105\n\tstorj.io/storj/storagenode/hashstore.New:85\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).getDB:271\n\tstorj.io/storj/storagenode/piecestore.NewHashStoreBackend:105\n\tstorj.io/storj/storagenode.New:618\n\tmain.cmdRun:84\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272\n\tmain.cmdRun:86\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272”}
Error: Failed to create storage node peer: hashstore: unable to flock: hashstore: resource temporarily unavailable
main.cmdRun:84
main.main:34
runtime.main:272
2025-01-31 19:22:34,343 WARN stopped: storagenode (exit status 1)
2025-01-31 19:22:34,344 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
How is your datastore mounted.
See the comments from Alexey in this thread.
It is HDD (ext4) passed trough proxmox to VM.
This setup was working fine for years. But yesterday failed and i cannot repair it :expressionless:
This error seems not related to not supported flock on a network filesystems.
Could you please check this disk for issues and fix them?
That error indicates some other process already has a lock on the same hashstore. Is it possible you have multiple nodes configured to use the same storage directory?
It also happened to one of my nodes last night, which was working fine, after updating to 1.121.2, it gave the hashstore flock error. I haven’t activated the migration, I’m still on piecestore. I threw away the bin, piecestore, filestatcache folders, removed and recreated the node and it finally started
Did it say "unable to flock: hashstore: resource temporarily unavailable" or was it "unable to flock: ..." something else?
There should be no reason for “resource temporarily unavailable” to show unless something else has a flock on the file for some reason.
Unfortunately I didn’t save the error, I was busy restarting the node, but I think that was it. In my opinion it has to do with the badger cache, but I’m not an expert, I’ll throw it out there
I have this error again
2025-04-12T11:37:09Z ERROR failure during run {"Process": "storagenode", "error": "Error opening database on storagenode: database: orders couldn't be read (\"config/storage/orders.db\"): stat config/storage/orders.db: input/output error\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:359\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:337\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:302\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272", "errorVerbose": "Error opening database on storagenode: database: orders couldn't be read (\"config/storage/orders.db\"): stat config/storage/orders.db: input/output error\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:359\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:337\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:302\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272\n\tmain.cmdRun:69\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272"}
I threw away the bin, piecestore, filestatcache folders, removed and recreated the node but don’t work
the database are ok
You need to stop the service and check and fix the filesystem, it’s corrupted or your disk is dying.
