And now this error pops up on the logs, running 1.96.6
Any thoughts?
Have you tried to search the log for that piece ID ?
Unfortunately this is mean two things: either these pieces are corrupted, or lost.
The outcome is the same - your node likely failed this audit.
I haven´t. I don´t even know how…I almost don´t interfere with it.
The next line after migrate would be failed to delete piece with a reason. Most likely it says file does not exist. You can search the log based off of the piece id in this line. Its just a warning so you can ignore it. The piece’s entry will be deleted from the database.
I have encountered migrate warning during piece deletion.
WARN pieces failed to migrate v0 piece. Piece may not be recoverable {"process": "storagenode"}
WARN retain failed to delete piece {"process": "storagenode", "Satellite ID":
Oh, then it’s better. The piece should be deleted anyway. I immediately thought that it’s during audit.
