Tried to follow all steps in this gentleman’s video
when I click on the “storage node dashboard” app I get “problem loading page localhost:14002”
Here are my thoughts on where I might have gone wrong. I have two ISP’s in my house. one from xfinity and one from WOW! cable. I set everything up according to the video above using WOW!/Arris router and couldn’t get connected. I realized the Arris router is far way from my mining computer and realized it only downloads at about 5 mbps.
So I switched to xfinity with Deco router.
I then used the Deco app to turn on port forwarding with the following settings service Type: DNS External Port: 28967 Internal Port: (blank) Protocol: TCP
Next, I made sure the IP addresses under port forwarding in the deco app matched what I get when running “ipconfig” under command prompt
After that I ran ps as admin and copy and pasted this New-NetFirewallRule -DisplayName “Storj v3” -Direction Inbound –Protocol TCP –LocalPort 28967 -Action allow
I restarted the computer a couple of times and still no luck.
I am running DUC v4.1.1 if that makes a difference.
I would like to post that but after time I do it says I cannot post anything with more than two links. Tried to upload it as a screen shot and I got an error message that there was an error uploading
You specified your external address without port and also used a http:// before which is wrong.
Please, install Notepad++ and edit your contact.external-address: parameter (see https://docs.storj.io/node/resources/faq/where-can-i-find-a-config.yaml), it should have your external address and port via colon:
contact.external-address: rrstorj.hopto.org:28967
Explicitly save the config (menu File - Save, this is mandatory step) and restart the storagenode service either from the Services applet or from elevated PowerShell:
