Failed to settle orders: EOF, deadlock detected?
Hi guys.
I still have this error in my main node after the update to 0.19.5
Is this an expected behaviour?
Please see Workaround for order sender errors (execute this before they expire)
Thanks for reporting it.
Just rebooted my SNO as in the workaround…issue remains :frowning:
You may need to restart the Storage Node several times, but even with that, it may not be fixed.
We have implemented a workaround and we’re now planning to release it as soon as possible.
Thanks for your patience.
Thank you, but in that case I´ll just wait. I prefer not to rebooted as I´m away from my node, and don´t want to risk being DQ´ed. I´ll wait for a release fix.
@ifraixedes The update to v0.19.6 has not resolved the issue on my node. Here is the relevant log snippet:
2019-09-02T19:34:44.813Z        INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       sending {"count": 24}
2019-09-02T19:34:45.066Z        INFO    version running on version v0.19.6
2019-09-02T19:35:30.262Z        ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       gRPC client error when receiveing new order settlements       {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-02T19:35:30.265Z        INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       finished
2019-09-02T19:35:30.267Z        ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       failed to settle orders       {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Please advise what I should do to correct this problem. My node has been doing this for several days (on v0.19.5 as well).
Hey @cdhowie and welcome to the forums!
Please, check out this thread:
https://forum.storj.io/t/workaround-for-order-sender-errors-execute-this-before-they-expire/1399/3
@Dylan That fix works on occasion. I’m mostly commenting here to point out that the fix in v0.19.6 has not resolved the problem; these errors persist after upgrading.
Any chance these errors cause a disqualification or reputation downgrade?
No, they don’t cause any of them.
Ok, thank you. I´ll just leave it at it is then.
We are figuring out why the deadlocks are happening.
As we commented the v0.19.6 is a workaround not a solution.
I’m asking my mates if they can give you some advise because I cannot.
Thank you.
I´m good with them until a solution is figured out, as long as it doesn´t cause DQ or reputation harm. This is what a Beta is all about :wink: no worries.
Hello everyone, my node is the same, even in 0.19.6 I am getting the deadlock message.
2019-09-03T10:45:38.497446826Z 2019-09-03T10:45:38.497Z INFO    orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs      sending {"count": 11}
2019-09-03T10:45:38.497495808Z 2019-09-03T10:45:38.497Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      sending {"count": 54}
2019-09-03T10:45:38.497504213Z 2019-09-03T10:45:38.497Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       sending {"count": 632}
2019-09-03T10:45:38.497585155Z 2019-09-03T10:45:38.497Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      sending {"count": 5}
2019-09-03T10:45:39.206828353Z 2019-09-03T10:45:39.206Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      finished
2019-09-03T10:45:39.312526769Z 2019-09-03T10:45:39.311Z INFO    orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs      finished
2019-09-03T10:45:39.623264785Z 2019-09-03T10:45:39.623Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      finished
2019-09-03T10:45:59.890343581Z 2019-09-03T10:45:59.889Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       gRPC client error when receiveing new order settlements {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T10:45:59.890392923Z 2019-09-03T10:45:59.890Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       finished
2019-09-03T10:45:59.890505163Z 2019-09-03T10:45:59.890Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       failed to settle orders {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T11:45:38.510625093Z 2019-09-03T11:45:38.494Z INFO    orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs      sending {"count": 1}
2019-09-03T11:45:38.510635652Z 2019-09-03T11:45:38.494Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       sending {"count": 677}
2019-09-03T11:45:38.510639590Z 2019-09-03T11:45:38.494Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      sending {"count": 48}
2019-09-03T11:45:38.510643187Z 2019-09-03T11:45:38.494Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      sending {"count": 8}
2019-09-03T11:45:39.182965267Z 2019-09-03T11:45:39.182Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      finished
2019-09-03T11:45:39.398953207Z 2019-09-03T11:45:39.398Z INFO    orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs      finished
2019-09-03T11:45:39.797840844Z 2019-09-03T11:45:39.797Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      finished
2019-09-03T11:46:58.743741991Z 2019-09-03T11:46:58.740Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       gRPC client error when receiveing new order settlements {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T11:46:58.743794289Z 2019-09-03T11:46:58.741Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       finished
2019-09-03T11:46:58.743800681Z 2019-09-03T11:46:58.741Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       failed to settle orders {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T12:45:38.494997679Z 2019-09-03T12:45:38.494Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      sending {"count": 6}
2019-09-03T12:45:38.495086756Z 2019-09-03T12:45:38.494Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      sending {"count": 51}
2019-09-03T12:45:38.495167076Z 2019-09-03T12:45:38.494Z INFO    orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs      sending {"count": 1}
2019-09-03T12:45:38.495183517Z 2019-09-03T12:45:38.495Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       sending {"count": 731}
2019-09-03T12:45:39.299850481Z 2019-09-03T12:45:39.299Z INFO    orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs      finished
2019-09-03T12:45:39.307749743Z 2019-09-03T12:45:39.307Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      finished
2019-09-03T12:45:39.592468396Z 2019-09-03T12:45:39.592Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      finished
2019-09-03T12:46:35.226016925Z 2019-09-03T12:46:35.225Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       gRPC client error when receiveing new order settlements {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T12:46:35.226092807Z 2019-09-03T12:46:35.225Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       finished
2019-09-03T12:46:35.226104909Z 2019-09-03T12:46:35.225Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       failed to settle orders {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T13:45:38.498570764Z 2019-09-03T13:45:38.498Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      sending {"count": 6}
2019-09-03T13:45:38.498632730Z 2019-09-03T13:45:38.498Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      sending {"count": 45}
2019-09-03T13:45:38.498678746Z 2019-09-03T13:45:38.498Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       sending {"count": 781}
2019-09-03T13:45:39.420122660Z 2019-09-03T13:45:39.419Z INFO    orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S      finished
2019-09-03T13:45:39.651850706Z 2019-09-03T13:45:39.651Z INFO    orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6      finished
2019-09-03T13:46:11.924526591Z 2019-09-03T13:46:11.923Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       gRPC client error when receiveing new order settlements {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-09-03T13:46:11.924605308Z 2019-09-03T13:46:11.923Z INFO    orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       finished
2019-09-03T13:46:11.924618593Z 2019-09-03T13:46:11.923Z ERROR   orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW       failed to settle orders {"error": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected", "errorVerbose": "order: failed to receive settlement response: rpc error: code = Unknown desc = pq: deadlock detected\n\tstorj.io/storj/storagenode/orders.(*Service).settle:311\n\tstorj.io/storj/storagenode/orders.(*Service).Settle:191\n\tstorj.io/storj/storagenode/orders.(*Service).sendOrders.func2:170\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
