Hi,
I’ve followed the instructions/guide on how to install a storagenode on my Synology NAS and apart from the email/wallet the settings are identical. However when it runs it fails with this error:
Error: Error creating tables for master database on storagenode: migrate: database: info opening file “config/storage/info.db” failed: unable to open database file: no such file or folder
I can see the mount points are correct:
"Mounts": [
"Type": "bind",
"Source": "/volume1/docker/storj/identity",
"Destination": "/app/identity",
"Mode": "",
"RW": true,
"Propagation": "rprivate"
"Type": "bind",
"Source": "/volume1/docker/storj/data",
"Destination": "/app/config",
"Mode": "",
"RW": true,
And are valid:
Phil@Pan:~$ ls /volume1/docker/storj/identity
ca.1682632435.cert ca.cert ca.key identity.1682632435.cert identity.cert identity.key
Phil@Pan:~$ ls /volume1/docker/storj/data
config.yaml orders revocations.db storage
Phil@Pan:~$ ls /volume1/docker/storj/data/storage/
blobs garbage storage-dir-verification temp trash
It seems to have already created a recovations.db file storage folder… So I don’t understand why it is not creating the info.db database in the storage folder?
Any hints on what could be wrong here?
Many thanks,
Phil.
