Fastest way to calculate folder size?
I need to calculate the size of a folder within a bucket without iterating through all of the objects’ metadata, such as with S3 SDK’s ListObjects feature.
Does Store provide any method for fetching storage metrics down to a bucket folder level?
You can see buckets from the web dashboard, but I wouldn’t know if it’s possible to see folders within buckets
You may use rclone ncdu storj:, if you configured rclone
If you want to calculate programmatically, you need to use a list of Objects and iterate over it to get the sum of the size of each Object.
